Thread: Cam follower empty!!!
    STOKE-ON-TRENT
    Default Cam follower empty!!!
    has anyone had this problem with their 1.9 cdti 150, sometimes when the car is cold i get a ticking noise just like a follower has emptied all the oil out, after about three miles it seems to go away, it doesn't always do it, and the car as only covered 17000 miles, any ideas?
    Oct 2007
    Ripon
    Any Update as I have the same problem I guess. Doesn't happen every time .... more when the car has been stood for a period of time or not on level? Once warm all fine.
    Service being done monday so see what fresh oil does.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Do they have hydraulic tappets?
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    If it's got hydraulic tappets, then you can get oil flow out of them overnight. The Slight tapping goes when they refill themselves with oil.
    I think from memory that it won't do any damage long term, but someone correct me on that if thats not the case!!!
    Yorkshire
    This can more apparent if the wrong grade of oil is used.
    Regular Member pogo's Avatar
    Feb 2006
    Vehicle : Audi
    Trim : A5
    Engine : 2.0 turbo petrol
    tbh it sounds like diesel clatter too me when engine is cold and once the cast iron blocked engine heats up the noise goes,imio just a healthy normal diesel engine
    Oct 2007
    Ripon
    Mine def not normal start up noise .... almost metallic rattle noise goes once engine been run up ....will only do after car has been left idle for a couple of days or paked on a slant?? In for service tom see if changes after fresh oil?
    Regular Member ion's Avatar
    walsall
    I seem to remember mine could be a bit clattery until warm.
    If youre not sure mate, get it checked to put your mind at rest.
  1. what to do when the bottles are empty
    By opel_estate in forum Comedy & Humour
    Last Post: 8th June 2012, 13:56
  2. empty fuel???
    By SRimonkey in forum Vectra C / Signum Car Chat
    Last Post: 18th April 2010, 20:07
  3. House seems empty
    By ed taylor in forum General Chat
    Last Post: 17th September 2006, 12:38
