Thread: code reader
    Aug 2007
    scotland
    Default code reader
    hi there just bought a code reader from mac tools as my engine light came on.quite impressed with it as the oygen sensor after cat faulty.it told at what rev temp and who often it happened.it only cost 50 quid when you can pay this just to get it checked once.
    Regular Member hudz's Avatar
    northern ireland
    I got 1 of these from Gendan,worth every penny!
    Regular Member baztheman's Avatar
    washington tyne & wear
    Thumbs up
    hi all i have just ordered one from eeebay,here the pics and specs (i hope it works ok on the veccy)
    heres the blurb
    Prints data via your PC!
    Reads live PCM datastream!
    The MaxiScan MS509 OBDII/EOBD Scanner supports all nine OBDII test modes on all OBD2 compliant vehicles to enable technicians to accurately diagnose even the toughest problems. Sophisticated yet easy-to-use!
    Features
    »Works on all 1996 & later OBD2 compliant US, European & Asian vehicles.
    »Easily determines the cause of the “Check Engine Light”.
    »Retrieves generic (P0, P2, P3, & U0) & manufacturer specific (P1, P3, and U1) codes.
    »Turns off Check Engine Light, clears codes & resets monitors.
    »Displays DTC definitions onscreen.
    »Views freeze frame data.
    »Displays monitor & I/M readiness status (emissions).
    »Identifies pending codes.
    »Reads live PCM datastream.
    »Displays live O2 sensor test data.
    »Graphs data – (1996 and newer).
    »Reads, stores & playbacks live sensor data.
    »Memory/battery backup for off-vehicle data review & analysis.
    »Bilingual interface & definitions—English/Spanish.
    »Performs modules present test.
    »Retrieves vehicle information (VIN, CID and CVN).
    »Supports CAN (Controller Area Network) & all other current OBD2 protocols.
    »Built-in OBD2 DTC lookup library.
    »Large easy-to-read backlit LCD screen.
    »Software upgradeable via internet.
    »Prints data via PC.
    Includes
    »User's Manual
    »6-foot OBD II cable
    »CD with DTCs and definitions & User's Manual
    »USB cable
    »9V battery
    Nylon carry case
    Mar 2007
    Worcs
    lol i just orderd that one, VUX see me more then my wife.
    Quote Originally Posted by baztheman View Post
    heres the blurb
    Features
    Includes
    »User's Manual
    »USB cable
    »9V battery
    »Nylon carry case
    Regular Member Steel's Avatar
    Sheffield
    Trim : Sri
    Mileage : 198,500
    For the money they are spot on. EOBD is common to all cars so anything emissions related shold be covered. Even some of the more expensive kit doesn't cover Vectra C on anything other than EOBD so anything emissions related (and some auto box functions as they can relate to emissions) is generally covered. Pretty good value.
    When VX serviced mine last year and they put a fault on it (fuel rail pressure sensor, presumably because when they changed the fuel filter they didn't reset it) the cheapest piece of kit we have cleared the fault on Diesel EOBD.
  1. Code reader
    By phil0464 in forum Vectra C / Signum Car Chat
    Last Post: 13th September 2012, 22:05
  2. Birmingham - Code reader / live data reader
    By awilson1234 in forum Engine & Drivetrain
    Last Post: 26th September 2011, 16:55
  3. For Sale: Code Reader
    By lizard in forum Parts for sale
    Last Post: 5th July 2011, 11:48
  4. Code Reader
    By Paddy in forum Engine & Drivetrain
    Last Post: 4th April 2011, 21:21
  5. Code reader
    By Paddy in forum Vectra C / Signum Car Chat
    Last Post: 27th March 2011, 18:21
