Thread: advice needed
    Apr 2008
    NW England
    Default advice needed
    Hi , i bought a vectra C life a few weeks back , took it for a test drive and all was well , it is a 1.9 cdti auto ( wifes car ) , the engine managment light was on and they said they would fix it , this was 2 weeks ago as the the plates were being changed , anyway collected the car today and the light is still on , they said it is OBD exhaust gas re circulation and as it is still with in warrenty vauxhaull should fix it , is this a common fault ?
    second one and a little more worrying
    when at 60 - 70 mph and you put you foot down it shows D and the revs just rise and the car slows , if i select triptronic type thing it will drive fine in all the gears except 5th ?
    Andy
    Regular Member skyrocketpilot2's Avatar
    daventry
    they have a recall on those for the inlet manifold,same fault code,they also replace the egr valve,they both suffer from alot of soot (carbon build up)then just run slugish...best get to the dealer and check the warrenty matey..
    Apr 2008
    NW England
    going to call at the local dealers tmra and see what they say
    the gear box worries more than anything , i dont want to ask for my money back as the car is spot on
    Apr 2008
    NW England
    spoke to the dealers ... they say the part is on back order and could take a month to come in
    tried the car again today and when stuck in traffic the temp gets to 90c and at this point the gear box plays up .. Vauxhaull say this could be caused by the other fault .. cant see it me self
    any ideas ?
  1. Advice Needed
    By Doddy01 in forum Vectra C / Signum Car Chat
    Last Post: 4th November 2010, 15:35
  2. a little advice needed please
    By mublin in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2010, 16:11
  3. advice needed
    By iasha in forum Vectra C / Signum Car Chat
    Last Post: 10th July 2009, 10:42
  4. advice needed
    By taxidriver50005 in forum Bodywork & Interior
    Last Post: 1st June 2009, 15:30
  5. advice needed
    By lizard in forum Electrical & ICE (including SatNav)
    Last Post: 12th November 2008, 19:36
