Results 1 to 10 of 13
Thread: help - 1 wiper packed in
    SCOTLAND
    Default help - 1 wiper packed in
    Hi guys,
    To cap a very pants 3 weeks was driving home from work and just went to head 30 miles out to my grans to check in on her only to find my passenger wipers not working.
    When the wipers are off at the stalk if i get out the car and try to move them manually the driver one wont move but the passenger one can be moved full sweep by hand. Yet if you operate as normal from inside the car only the driver one works.
    Any ideas? i thought a fuse but surely that would affect both?
    thanks in advance.
    Regular Member skyrocketpilot2's Avatar
    daventry
    wiper linkage.or the arms loose,13mm nut under the cap at the end.but pretty sure its the linkage as a common fault mate
    Regular Member Sawyer Reynolds's Avatar
    Sounds like the wiper linkage to me.
    Happened on my old tatty Punto before, I just put a blob of super glue around the edges and never had a problem again. Obviously, I'd suggest a proper fix for a Vectra, ha.
    Regular Member Damian's Avatar
    Market Drayton
    So common in fact that the AA when you call them out have some fudge fix for it to get you going again by the side of the road. Happened to me about 2 years ago, he told me he gets called to loads of Vectras where the linkage breaks.
    I believe it was a recall item (not sure) i had it replaced at the time under warranty , the dealer seemed to be aware how common the fault was
    daventry
    yeah they do it under warenty,but not a recall as there all gonna break,they use uprated ones now as the ball joint rusts and simply falls off.i do so many you wouldnt belive it...honest
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    There's a how 2 for the fix G.
    Regular Member sparky71a's Avatar
    Apr 2006
    At the Garage
    Go and get a plastic pull through cable tie,normally get packs of 100 for next to nowt. Pull the plastic sill on the car back so you can see the linkage,a small joint(looks a bit like a ball joint) will have worn and worked apart,put your fingers underneath the dropped bit,place the joint back together,now while your holding the joint in place,put the cable tie around,pull through the one way locking bit on the end of the tie and GENTLY adjust,so the cable tie holds the joint up but DOESN'T prevent it from moving back and forth.
    Such a solution held mine in place in all weathers for a fortnight till it was fixed under warranty.
    And i did it myself when mine went in torrential rain on the M50
    daventry
    i still have the cable tie "mod" on mine 4 years later..atleast its rust free..got the linkage but just carnt be ar$ed to do it..
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    On mine, the central pin came adrift from the motor arm. A quick touch with the welder, some copper grease in the ball joints and all has been well for well over a year.
    There is LOADS about this failure on here.
    SCOTLAND
    cheers for the replies guys. just seen the how to so will try the stealers tomorrow or call the rac to do a temp fix till i get one. at least the drivers sides working lol
    cheers again
  1. Air con packed in.
    By johnseffs in forum Vectra C / Signum Troubleshooting
    Last Post: 6th October 2011, 16:24
  2. Wtf! Passenger Wiper Packed Up.
    By kev bux in forum Bodywork & Interior
    Last Post: 16th January 2010, 14:16
  3. memory seats packed in,auto wiper/light not working etc etc
    By uaintsinme..right in forum Electrical & ICE (including SatNav)
    Last Post: 30th August 2009, 18:24
  4. Dpf has packed up
    By ANDY W in forum Engine & Drivetrain
    Last Post: 10th August 2009, 17:53
  5. sky+ just packed up
    By coylo5 in forum The 'Off Topic' room
    Last Post: 7th August 2009, 10:44
