Results 1 to 3 of 3
Thread: Auxilliary drive belt change 2.2 Direct
    Oct 2007
    teddington
    Unhappy Auxilliary drive belt change 2.2 Direct
    This is my first post so please excuse the lack of formalities. I am struggling to complete a job that has never taken me longer than 30 mins on all my previous cars. As advised in Haynes manual I have removed the rhs front wheel arch inner cover but to my extreme disappointment this does not provide any obvious (to me anyway!) access to the tensioner to release the belt. There is a small hole in the exposed wheelarch which it might be possible to poke a thin bar or a screwdriver through to perhaps lever upwards the tensioner. Is this how it's done? I haven't removed the air filter housing as I don't think this would provide much better access from under the bonnet but I could be wrong. Any advice gratefully received.
    Oct 2007
    teddington
    Smile job done
    A bit disappointing to receive no help from forum members but I guess diy servicing & maintenance is a minority sport these days. For the benefit of anyone else struggling with this, the procedure described in the Haynes manual is hopeless. Removing the inner wheel arch cover doesn't provide any access to the tensioner (not on my 2.2 direct sri anyway). With pit access to the underside I removed the lower cover (4 screws including 1 in the wheel arch), used a scissors jack (placed on a plank across the pit at floor level) to lever upwards against the underside of the tensioner with a piece of wood (3/4" square section) about 12" long. Still very little room to work but was just doable. Also had to put the new belt on the a/c compressor sprocket last as the crankshaft one has a wide lip and there was too little slack in the belt. Not sure what would have happened to my fingers if the piece of wood had sprung away from the jack so take care. There surely must be an easier and safer way than this!
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Sorry you didnt get any help mate. If the guys in the know had seen the thread they would have definitely helped you out. Most guys come online after 5 ish so thats a better time to post. Glad you got it sorted and your advice will come in handy if anyone else comes across the same problem.
    Welcome to the site by the way. Don't let your first experience put you off.
  1. Auxilliary belt tensioner......2.2 DTI
    By the scouser in forum Engine & Drivetrain
    Last Post: 18th July 2009, 04:50
  2. Drive Belt help
    By SRIstu in forum Engine & Drivetrain
    Last Post: 11th May 2009, 11:10
  3. Urgent Help!! Fan/auxilliary belt fitment
    By buggy_666 in forum Engine & Drivetrain
    Last Post: 28th September 2008, 16:05
  4. Aux drive belt...
    By simp_2.2sri in forum Engine & Drivetrain
    Last Post: 6th October 2007, 10:26
change vectra c 2.2 fan belt
replacing fan belt vectra c 2.2
how do you adjust fan belt on vectra c 2.2 direct
vectra c 2.2 direct alternator belt
Vectra 2.2 direct belt tensioner
Fan belt replacement on vectra c 2.2 direct
vectra c z22se alternator drive belt replacement
