Results 1 to 10 of 18
Thread: Tyre Pressures
    Apr 2008
    North Herts
    Default Tyre Pressures
    Hi
    My first post ....so please be gentle with me
    I have a Vectra 1.8 Life (Feb 2006) with 205/55/16 Tyres
    The log book seems to show two lots of tyre Pressures
    Tyre pressure for load of up to 3 people = 29 Front & 32 Rear
    Tyre Pressure ECO loaded up to 3 people = 35 front & 38 Rear
    What is the difference or am I being thick ???
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Car will be more responsive and have better MPG with the ECO, but will be a bit more lethargic but smoother with the first set of pressures. Welcome to the site mate.
    Apr 2008
    North Herts
    If thats the case is there any point to setting the pressures in between the two points (hopefully that makes sense)
    Not tried the higher tyre pressures as wasn't sure.
    East Midlands
    To the site
    11 Post(s)
    Surely increasing the tyre pressures will wear the centre of the tyres out quicker than the outer edges as they'll be over inflated?
    Regular Member Grem's Avatar
    uk south mainly
    Hi Mate
    I have experimented with the tyre pressures ref your comments and my findings are:-
    When I increased pressures to the ECO settings (higher PSI) I noticed the following.
    1. Increase in MPG - aprox 4mpg on the computer.
    2. Slightly smoother on the motorway miles and eco driving on A road.
    Downside.
    Slightly less gripp as typres are really blown up to max.
    I do the following - Eco settings in summer months and normal in winter, and a bit of in between in spring and autum.
    Hope this helps.
    Apr 2006
    Kingswinford
    Trim : LS
    Engine : 2.0 DTI
    Mileage : 150000
    I was told by VX mechanic, best to keep it at 34 all round.
    Vehicle : SRi
    Mileage : 137000
    My tyres have a MAX inflation of about 50 psi marked on the side, so running 38 is well within there tolerances. Also there are metal bands running around the tyre so its not going to balloon.
    11 Post(s)
    I'm not talking about the max pressure limits the tyres can handle.
    What I'm referring to is that an under-inflated tyre will cause the tyre to wear on the outer edges of the tread, leaving the central tread area far less worn.
    Whereas an over-inflated tyre will cause the centre of the tyre to wear out far quicker than the outer edges.
    Regular Member wingers1982's Avatar
    barnsley
    im a tyre center manager and in our books we get it says 34 psi all around
  1. Tyre pressures
    By Chewy72 in forum Vectra C / Signum Car Chat
    Last Post: 9th March 2012, 01:00
  2. Eco tyre pressures
    By Mike57 in forum Handling & Braking
    Last Post: 29th February 2012, 14:31
  3. Tyre Pressures
    By Tango in forum Vectra C / Signum Car Chat
    Last Post: 18th October 2009, 00:10
  4. Track Use Tyre Pressures and Tyre Temperatures
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2009, 23:04
  5. Tyre Pressures
    By johnmac in forum Vectra C / Signum Car Chat
    Last Post: 27th September 2006, 00:49
