Results 1 to 10 of 13
Thread: product num for meg glaze/sealant?
    Regular Member Craig1985's Avatar
    harwich essex
    Default product num for meg glaze/sealant?
    anyone got the product num for meg glaze/sealant plz? or a good glaze/sealer?
    Mileage : 000
    #7 is showcar shine which is a glaze .. if you want a decent glaze/sealer then Full Molecular Jacket (FMJ) is the mutts nuts , bit pricy though ..
    Chester
    #7 is the Glaze. As Tommy says.
    #21 is the Sealent.
    Regular Member jontymo's Avatar
    Feb 2007
    Huddersfield
    Megs#21 sealant, i use it over AG SRP and lastly stick 2 layers of Collinite 476s on. 2 months down and still beading well.
    jontymo
    harwich essex
    when someone talk of meg#21 for example is the #21 the product number? my local car shop doesnt know of this he said its a number eg m0123?
    Feb 2007
    Huddersfield
    you might struggle to get it local, if you go on cleanandshiny.co.uk you will see the products under sealants/waxes, the product number for the megs#21 is M2116 for the 473ml bottle, they price at £19.25 + p&p.
    If you can get someone to share with you can get a 1890ml bottle for £40.42 so nearly double for the same price, you can buy empty bottles etc from them. you do not need to use a lot the emphasis is on less is more with these products. I used cleanandshiny for my megs and collinite and have seen them at a detailing day on here so can recommend.
    Jontymo
    Chester
    It's the Meguires number.
    From when I did the missus motor
    Aug 2007
    Let me just offer some advice to help you guys get value for money. If you are going to use a sealant, try to avoid glazes.
    Glazes contain lots of oils. Sealants need to fully bond to the paintwork to provide the durability. It will struggle and not bond as it should if the car has glazes on it.
    If you are using a sealant, and also going to top with something like 476s, which will last around 6-12 months on its own from a single layer, consider if buying the sealant is worth the money and effort to use.
    Sunny Dartmoor
    So what sealant and wax do you recommend?
  1. Product Test: AD Extreme Glaze Vs AG SRP
    By Ginge7289 in forum Detailing and Car Care Discussion
    Last Post: 13th November 2011, 09:13
  2. Diamond Glaze
    By oxenburger in forum Detailing and Car Care Discussion
    Last Post: 6th August 2009, 17:02
  3. After a glaze and wax.
    By Stevel in forum Quick Photo Album
    Last Post: 4th May 2008, 05:44
