Thread: Bleeding diesel engine
    Regular Member bigbenny4gf's Avatar
    Aug 2007
    DERRY CITY
    confused Bleeding diesel engine
    if a 2003 vectra 2.2dti runs out of diesel does it bleed itself when you put more diesel into it or what is the procedure?
    Regular Member Steel's Avatar
    Sheffield
    Trim : SRI CDTI NAV
    Mileage : 202,800
    You need a bulb pump like the one the used to have on Peugeots. Oh, on the tool to remove the clips on the fuel filter. The pump goes in line after the fuel filter and pulls fuel through and into the pump. They can be a right pig to bleed sometimes.
    Regular Member Dal150's Avatar
    Apr 2008
    Leeds
    Default Hi all (Newbie)
    Aug 2007
    DERRY CITY
    hi Steel,its just that i ran outta diesel today and when i put more juice into the tank i used my past experience of running outta juice in a diesel corsa and just turned the key until engine finally started.And it did start eventually.So maybe i didnt run out of juice??or can it start this way?
    thanx again cause me is dopey
    Last edited by bigbenny4gf; 9th April 2008 at 00:58. Reason: left out the main mans name
    11 Post(s)
    To quote from the handbook:
    Diesel fuel system, bleeding
    It is possible to restart the engine if the tank has been run dry. A delayed start is to be expected. Attempt to start the engine for a maximum of 60 seconds. If the engine does not start, wait a few minutes and try again.
    Regular Member signum junkie's Avatar
    Edinburgh
    Would put some sort of injection /fuel cleaner in just incase, you don't know wht kind of muck has been sucked through
    if it won't self prime, remove the top of the fuel filter and prime there with an overfill of either diesel or fuel treatment( both will burn to start the car) and replace the top securely.. the car will crank while the pump primes, but it will start..
    New Member dicthebig's Avatar
    Aug 2009
    Bulgaria,Italy
    Vehicle : Vectra C Y20DTH
    Engine : Y20DTH
    Year : 2002
    Mileage : 167000
    that may be work in case only the tank is emty.If you open injektor high presure way or leaking-off pipes or some other fuel way aroun the pump - than you need a real bleeding of sistem.
    Regards from sunny Bulgaria!
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    just tow it in 3rd or 4th gear
  1. Bleeding the air from the diesel fuel system
    By pete7175 in forum Engine & Drivetrain
    Last Post: 27th July 2016, 07:24
  2. bleeding bleeding and adjustment
    By noudder72 in forum Suspension, Wheels & Brakes
    Last Post: 26th December 2011, 11:29
  3. Need Info on Bleeding diesel pump
    By Pjuk in forum Engine & Drivetrain
    Last Post: 26th February 2011, 17:16
  4. Diesel bleeding
    By dti111 in forum Engine & Drivetrain
    Last Post: 6th February 2011, 17:08
  5. Diesel bleeding
    By craigbarlow18 in forum Engine & Drivetrain
    Last Post: 25th September 2009, 19:31
how to prime a vauxhall diesel engine
how to bleed a 2.0 diesel vectra.enginewalkthru how to bleed diesel vauxhal vectrawalkthru bleedin vauxhall diesel enginevauxhall vectra c 2.2 dti sri ran out of dieselhow to prime a diesel enginehow do you bleed a vaxhaul frontera when it runs out of deseilbleeding diesel system vauxhaull vectra 2l diesel 2002vectra c 2.2 out of fuelhow to bleed the air out of the diesel on a 2005 signum 2.0 dti without a bleeding kitvauxhall vectra dieselhow to bleed cdti diesel bleed vectra c dti fuelz19dth diesel bleedhow to prime a vauxhall 2.0dtihow do you bleed a diesel vectra carhow do i start a vectra diesel after running it out of fuel2.2 d vectra 02 diesel bleedervectra c y20dth www.vectra-c.combleeding diesel engine vauxhall vectrahow to bleed an insignia fuel filter53 vauxhall vectra 2.2d engine code p0300bleeding a vectra c dieselhow to bleed a 2ltr vectrehow to start a vectra c diesel when run out on fuel
