Thread: front bush?
    bradford
    confused front bush?
    i keep getting a really bad creaking noise when i go over bumps and speed bumps in the road, i've checked all the usual even radiator mounts..
    took it to a friend who's a vauxhall mechanic and he seems to think it could be a front bush or rear bush he's not sure
    anyone experience these problems before??
    any thoughts
    cheers in advance
    front antiroll bar bushes... common as water...about £1.50 each from VX and can be changed without lowering the subframe...dead easy..
    Apr 2006
    Kingswinford
    Trim : LS
    Engine : 2.0 DTI
    Mileage : 150000
    Is there a "how to" to replace these antiroll bar bushes ?????? Or could someone post one.
    Feb 2007
    Glasgow
    Regular Member bill1250's Avatar
    Apr 2008
    Hampshire, England
    How many miles has your car done? if its alot its possible the bushes wear out and need to be replaced
    Apr 2006
    Kingswinford
    Trim : LS
    Engine : 2.0 DTI
    Mileage : 150000
    Cars done 60k, only noisy when I go over the small speed humps. The ones that are near junctions/traffic lights. I hear a clonk when I go over them slowly, otherwise its fine.
    Regular Member bgm46's Avatar
    South Queensferry
    Liam,
    I had the same and also thought it was the anti roll bushes, turned out it was the rear bush of the front wishbone arm (think thats what its called)
    £37 each and quite easy to do. Sorted the noise completely.
  1. Front wishbone bush
    By dave300776 in forum Handling & Braking
    Last Post: 13th December 2012, 14:02
  2. Front ARB bush
    By stevie16v in forum Suspension, Wheels & Brakes
    Last Post: 25th November 2012, 19:51
  3. Identify front ARB bush
    By ScotsDragon in forum Suspension, Wheels & Brakes
    Last Post: 28th August 2012, 14:38
  4. Front Bush Thickness
    By CraigoT in forum Handling & Braking
    Last Post: 12th August 2012, 19:37
  5. front arb bush size?
    By TimTay in forum Suspension, Wheels & Brakes
    Last Post: 6th January 2011, 19:59
