Thread: message "P0300" one or more cylinders failure
    Jan 2006
    Mexico
    Thumbs down message "P0300" one or more cylinders failure
    Hello, there....
    I have a Vectra C signum 2004, and several times have seen the message P0300 over the hand-held terminal of my Chevrolet distributor. They have actually taken my car for inspection and they say to see nothing wrong on my car regards motor issues. they say is an intemitent failure, and it is not "present" always, so they can not see the failure and get it fix.
    Is there any one who may have or had a problem like this and get me some recommendations to do?
    I just notice that the motors vibrates a little on the mornings compared to when it was new, in 2004....... as a matter of fact ....just ONE time 2 months ago, just exiting from a parking lot, at low speed have experimented a strong vibration in the motor. Actually I turned off the car and waited, then turned ON again, and then the car continued normal again as today. I just thought that it could have been the fuel.
    well, please advise.
    thanks.
    Salvador Castañeda.
    Hasn't this been posted today already? Here
    Norfolk 'n Good Drives : Signum 3.0 CDTi BHP : 229.8 Torque 344.9lb
    Quote Originally Posted by Jamie1979
    But this is the thread in the right location now.....
    Still no idea though - sorry salvadoree.
    Yes m8,but he was posting as a guest - now he's done the right thing and registered and posted here.
    Salvadoree - glad you signed up. What engine do you have? That may help people to come up with any suggestions.
    Sounds like the slow failure of the Coil pack. Normally goes with heat. ie, the hotter it is the more it breaks down.. Symptoms exactly like when it failed on my little brothers 'C'.. Replaced under warranty in his case.. Ask them to substitue a new one and see if the fault vanishes..
    HTH..
    Jan 2006
    Mexico
    Wink Thank you.
    First of all, I would like to thank you all, who respond with a reply to my problem.
    regards, if my message is in the right place, mmmm sorry, I do not know if it was....., I am new on this site, but just let me know how to do it right.
    thanks "Gsi3.2" I´ll take note of your recommendation,.....
    Duncan thanks for welcom me, ............. regards the specs on my car here they are: if need more let me know.
    Is a Vectra 2004, C. Opel, but here in Mexico is Chevrolet, they did not allow to put the opel sign in front and behind of the car. The motor is a Motor ECOTEC 3.2 lit.
    I still have warranty, that is why I would like to fix this problem as soon as possible, my local Chevrolet service shop, said that becase is an intermitent failure they can not really detect the problem. They have cleared the faults again and said that if they come on again they would do something else, but I do not feel ok with this, since this last time I send my car to the shop, they told me that they have cleared the error list and made a "calibration" using the hand-held terminal connecting to the car computer; so I think that they might have changed some of the parammeters working range, so doing this I think the car is going to work out of design range, just for the reason of avoid the messages to come up again..... could this happen???
    well, in conclusion, I think they do not know what to do, or they take this problem easily and do not want to make nothing.
    Parallel to this problem my car last time I saw the hand-held terminal in the shop, I saw 50 messages, ... mostly regards to CAN Bus communication problems, on which they also told me thay these messages are not true messages. They were told by one of the persons in Mexico city in charge of Opel cars, that these messages are present but should be dismmissed, I mean not take care of them....
    well. .. . my question is..... and what if I talk about this to an engineer in Opel Germany about this messages? ...would he said the same?...
    I know CAN protocol is a very old communication,... kind of serial comm, but I think that there might be something wrong, ... there is too many messages related to CAN Bus communication problems,
    I know ....I wrote too much,,, but I wanted to take advantage, since you are a head of schedule, UK----Mexico....
    regards, thanks..
    SC
    Regular Member Robbieben's Avatar
    Dec 2005
    Polishing a car somewhere
    DTC Code lookup comes up with the following results
    DTC lookup results
    Main menu | Lookup code definition | Logout
    Fault code
    P0300
    Manufacturer
    VAUXHALL
    Definitions (1)
    More information (0)
    Symptoms (0)
    Probable causes (1)
    Fix information (0)
    Look up another code
    Same vehicle
    New vehicle
    Probable causes
    Add new entry
    Model: ALL Engine: ALL Fuel: Petrol (gasoline) Year: 2005
    Gendan Limited (United Kingdom) 2005-05-01
    Spark plug(s), HT lead(s), injector(s), ignition coil(s), low compression, wiring.
    Hope this helps. Confirms what Mark GSi3.2 said above
  1. "check light" fault message
    By danhariga in forum Electrical & ICE (including SatNav)
    Last Post: 25th September 2012, 15:50
  2. "Check Safeguard" Message
    By Loz2286 in forum Vectra C / Signum Troubleshooting
    Last Post: 14th February 2011, 16:47
  3. Great way to get the message across-"DRINK AND DRIVE"
    By Vaux-Man-G in forum General Chat
    Last Post: 23rd August 2009, 11:48
  4. "BRAKE LIGHT" Message in display...
    By Westy SRI in forum Electrical & ICE (including SatNav)
    Last Post: 12th December 2008, 23:35
vectra 3.2 p0300 fault code
vectra p0300 causes
