Results 1 to 10 of 15
Thread: rpm on clocks
    member of the smoke patrol 230bhp+
    Default rpm on clocks
    im looking for the rpm on the vectra c cdti iv been told its one of the green wire to the clocks
    can anybody comfirm this
    Melbourne, Australia
    Do you mean a wire inside the instrument cluster?
    The external signal to the cluster is sent via a low speed CAN message. This wire is green. Actually nearly everything the instruments display comes on this wire!
    im trying not to make a canbus interface to do the job im hopping to god i car pick up a rpm feed square wave so i done have to do the can
    Regular Member Swatty's Avatar
    Jul 2006
    greenock
    Iím probably imagining it - but I think I remember someone on the forum mentioning that there is either a speed or rpm signal going to the radio
    Quote Originally Posted by Swatty View Post
    thats a speed behind the radio
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    There has to be some sort of speed signal to radio, to enable and control the 'speed volume' adjustments to be made.
    If you just need / want a square wave, won't the ABS sensor provide that??
    Cirencester
    Quote Originally Posted by Ste View Post
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Cheers, must have made sense to someone then. In reality I don't know what sort of signal the ABS sensors produce, but it would probably be a square wave with the frequency related to the rotational speed and the number of 'teeth' on the ABS ring.
    Cirencester
    it will be a square wave, on and off Signal I imagine
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Are the on and off signal durations the same? Are the teeth lands depth the same as the gap distances ??
  1. 140mph Clocks To 170mph Clocks
    By Lean6 in forum Electrical & ICE (including SatNav)
    Last Post: 27th September 2012, 20:48
  2. help clocks gone off
    By J100RSA in forum Electrical & ICE (including SatNav)
    Last Post: 9th November 2010, 12:12
  3. clocks
    By dar in forum Bodywork & Interior
    Last Post: 7th December 2009, 22:14
  4. Gsi Clocks
    By VECTRA HEAD in forum Electrical & ICE (including SatNav)
    Last Post: 10th January 2009, 00:12
