Thread: Help needed please knocking/banging noise
    Regular Member phil67's Avatar
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    Default Help needed please knocking/banging noise
    Now that i have the car back from being painted, i am now interested in sorting some of the other probs with it.
    Its the facelift model 55 reg and it bangs/knock sounds like in the rear when i go over speed bumps and pot holes.
    Ive adjusted tailgate, removed the spare and tools, taken out the parcel shelf and still it makes the noise.
    Ive seen a few posts regarding the rear anti roll bar bushes could it be those but i thought i read somewhere that the facelift had slightly different set up.
    Any help would be great.
    Cheers Phil
    Regular Member Super T's Avatar
    May 2007
    On the Levels
    Check the springs!! My car broke one last week and it seems common.
    lanark
    5 Post(s)
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    are springs just an easy visual check or does it need to go up on a ramp wheels off etc
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    Any other ideas as the springs look ok?
    UK
    Phil, another thing to check is the rear control arms, top and bottom arms. Im not familiar with the facelift setup as mine is pre facelift, but there are a few mentions on this forum about these arms.
    Nov 2007
    lancashire
    real common on all vec b's and c's is rear anti rol bar bush's, dead cheap to fix. one bolt out which holds bush in place.cost a couple of quid each but hard to diagnose as faulty as ive never found play in them but replace them and noise goes away.
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    Cheers taxidriver
  1. Knocking Noise from Rear - Expert Advice Needed Please
    By Rebellion in forum Vectra C / Signum Troubleshooting
    Last Post: 17th September 2012, 19:48
  2. banging/knocking from rear
    By hay246 in forum Suspension, Wheels & Brakes
    Last Post: 2nd May 2010, 20:49
  3. banging noise
    By Onedda in forum Vectra C / Signum Car Chat
    Last Post: 29th September 2008, 10:11
  4. suspension banging noise
    By dan1983 in forum Vectra C / Signum Car Chat
    Last Post: 7th August 2008, 19:12
  5. Knocking/Banging from rear susp
    By coppjoe in forum Suspension, Wheels & Brakes
    Last Post: 10th February 2008, 14:48
