Results 1 to 10 of 15
Thread: towing a caravan?
    Cirencester
    confused towing a caravan?
    will my 1800 vectra Hatch 06 pull a 16 Ft van ok? single Axle
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    Not sure but you may struggle with the power. I tow a foldup camper with my cdti 150 auto and have no problems at all.
    Your cars weight, size etc is fine but again its your engine size that might let it down
    Regular Member Gr4eme's Avatar
    Feb 2007
    Durham
    What ANDY W said, would have concerns about the engine size.
    I used to tow with a vec b 1.8 and it did struggle up banks.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I would say similar, check the weights to ensure that's all OK. But the 1.8 may struggle towing any caravan.
    Cirencester
    OK thanks, where's best to get a tow bar and twins Fitted?
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Depends on what you want / can afford / ease.
    May 2007
    WINSFORD
    I shopped around and got one fitted localy to me, but watch out as quite a few companys wanted to cut my bumper but the company I used didn't and the Towbar make was Towsure and fitted by Norbrook Trailers at Stretton, Warrington. Sorry but I cant remember the price but he was the cheapest aswell.
    Inverurie
    Quote Originally Posted by JonR View Post
    In the back of the caravan mags you can get a chart which you plot your kerb weigth v axle weight of your van (I think these are the axes). If you cross the shaded area then the advice is it is not recommended combination.
    I remeber a while ago my Dad plotting a number of things based upon the van he has, against his list of potential company cars.
    Obviously the power output of the car plays a factor, lower output cars have to be worked harder/change gears more in order to kepp up with the flow of traffic especially if the road is hilly. If you are ok with this or a more laid back approach then you should be ok, if you want some grunt to do something you may struggle especially on an incline.
    Hope this helps,
    Andy
    Ashington, Northumberland
    I think you have your answer but for my two pence worth, I think you will definately struggle. Either way, you'll kill your car eventually
    Feb 2007
    Durham
    I would seriously be conderned about the clutch.
    Phone any caravan dealer and they will match your caravan to car and tell you your answer.
    Main problem i suffered with the 1.8 was on really steep banks the engine would die that much that i had to use 1st gear, you would build the revs up to change gear but once you select 2nd gear it would just die again, so back into 1st.
    Get a 1.9 cdti 150 i go up the same banks now in 3rd and fourth and still accelerating.
    The difference really is unbelievable.
  1. caravan
    By fjaimo10 in forum Vectra C / Signum Car Chat
    Last Post: 4th June 2011, 19:15
  2. Vectra 1.8i VVT Estate for towing caravan???
    By fastbatard in forum Introduce yourself.
    Last Post: 26th November 2010, 11:54
  3. Towing a Caravan
    By WeDesign in forum The 'Off Topic' room
    Last Post: 29th August 2010, 03:04
  4. GSi auto - towing a caravan
    By gtr1000 in forum Engine & Drivetrain
    Last Post: 22nd July 2008, 10:13
  5. Black Siggy Estate Towing Caravan
    By Taffyopel in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 28th March 2008, 10:46
