Thread: help with parking sensors
    Regular Member Dezza's Avatar
    Glasgow
    Default help with parking sensors
    Completed my first mod today. Fitted parking sensors, everything went ok until i tested them. Even when nothing is blocking them they will beep 6 or 7 times then they settle and work fine for a few seconds then they will beep again. this cicle seems to repeat over and over
    Could this be the bulb check causing the problem? meaning I need to fit the relay or do i have a faulty unit?
    Sensors are fitted in the location in the how 2 section so shouldn't be too low.
    cheers for any help
    May 2007
    West Yorkshire
    could be a power problem, mine bleep on start up so you know they are working, wire a temp supply direct to the batt (or cig lighter) this will prove the supply.
    Glasgow
    Quote Originally Posted by sshooie View Post
    Cheers mate, will try this tomorrow.
    Do you have the relay fitted?
    Sunny Dartmoor
    Could be a bad connection on the reverse feed..........:
    May 2007
    West Yorkshire
    Quote Originally Posted by Dezza View Post
    no, not on mine.
    Devon
    Try aiming them up a bit to see if it is ground/rough surface interference?
    Don't forget they 'see' a little sideways as well so make sure you are not near a fence or house or something on your rear quarter.
    Regular Member Gr4eme's Avatar
    Feb 2007
    Durham
    I had this problem also.
    turned out i had a faulty sensor. what you should do is go into the control panel and unplug 1 sensor at a time, if you have a faulty sensor, once you unplug it, it should stop beeping.
    also use the wedge shaped rings to point the sensors up a bit incase they are detecting the ground, hth.
    Glasgow
    Thanks for all the help guys.
    Think I've sorted it. I had used scotchlocks to tap into the live feed for the reverse light. i opened this up to make sure it was connecting properly and the wire was cut. connected it all back up using spade connectors and it seems to be working. So looks like it was a faulty live connection.
    I'll test it over the next few days and see how it goes!!
    Thanks again for the help
    Derek
    Darlington
    Derek - Could you post some pictures please. Which kit did you go for?
    Sunny Dartmoor
    Derek
    Think i stated that......
    Good job for getting it sorted............
  1. OE Parking sensors
    By Dippy-Vx-line Red in forum Electrical & ICE (including SatNav)
    Last Post: 19th January 2012, 19:02
  2. parking sensors
    By happypostie in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2009, 02:04
  3. HELP parking sensors
    By lee11 in forum Troubleshooting
    Last Post: 4th December 2009, 13:38
  4. Parking Sensors! Help!
    By Schui1024 in forum Electrical & ICE (including SatNav)
    Last Post: 5th October 2009, 23:52
  5. Parking Sensors
    By Mick B in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2008, 21:58
