Thread: detailing help hints and tips please
    Regular Member Craig1985's Avatar
    harwich essex
    Default detailing help hints and tips please
    when using an electric polisher, do you change the sponge pad for different substances eg. scratch x, polish, sealant/glaze, wax? or are some of these easier to do by hand?
    im scared of burning the paint or going through the clear coat. i tend to use a bottle of water and spray onto paint to keep cool..is this right?
    any help/hints/tips would be very much appreciated
    craig
    farnborough
    what polisher are you using mate?
    Forum Moderator FIL 4822's Avatar
    On a French Carp lake somewhere x
    6 Post(s)
    Vehicle : Insignia VX-line RED Tourer
    Trim : No, over weight!
    Engine : Flux Core Capacitor
    Year : 1 A.D
    Mileage : Rising
    Which machine do you have ?
    Beaten to the Q !!
    farnborough
    it all depends on what you are using equipment wise...
    very quick answer...
    what polishes are you using and name all products
    generally it should be ok, as the polishes are designed to cut the paint to get the paint to shine and remove swirls etc.
    farnborough
    oh, and what are you using scratch X for?
    6 Post(s)
    Year : 1 A.D
    Mileage : Rising
    If your using a Porter Cable of the new Meg's one , then theres little chance of damage as they are Random Orbital polishers, If you have a 9" angle grinder then YES you could well cause problems ! They are for the more professional detailer .
    You should be ok with most 'off the shelf ' products but always read the labels. They give you the best info on how to use them.
    If in doubt use on a test area.
    harwich essex
    i have a makkita one, (pro use 6 speed), was one merc had when they had a compound near mine but when closed down gave staff the tools they used. so my neigbour gave me it (not long b4 he died,bless him)
    has 6"! disc i think? only ever used speed setting one.......others scare me.
    used scratch x to get rid of szome light scratches...
    i got megs high glass wash, scratch x, polish, paint cleaner, glaze n yellow wax stuff oh and clay bar kit....but not sure best way of using it all?lol
    ££££££££££s spent now time to see results
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Just use the least aggressive combination first mate and work your way up, so least aggressive polish with least aggressive pad, you can never add paint! The Makita will have enough weight behind it so don't really need to apply pressure. There are some great guides on DW and if you look around You Tube the are some great ones on the from Megs USA. HTH
    Regular Member Steel's Avatar
    Sheffield
    Trim : Sri
    Mileage : 198,500
    Quote Originally Posted by vectra1.9cdti View Post
    Water is actually one of the best polishing mediums available when machine polishing, can get a bit messy when the compounding head is soaked through though but does give an excellent finish after compounding.
  1. Tips and hints for de soldering SMD leds
    By Jonsey in forum Electrical & ICE (including SatNav)
    Last Post: 10th February 2013, 13:28
  2. GT5 Hints and Tricks
    By spennny in forum Games Room
    Last Post: 16th January 2011, 12:19
  3. starting a detailing buisness, tips req
    By paul_sri150 in forum Detailing and Car Care Discussion
    Last Post: 22nd October 2010, 14:26
  4. any tips on how to cut the rear valance to show my exhaust tips
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2008, 18:58
  5. How2,hints,tips, on bleeding brakes plz
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2008, 12:21
