Thread: Towbar question regarding fitting
    Regular Member cheekylemon's Avatar
    Aug 2007
    Droitwich - Worcestershire
    Default Towbar question regarding fitting
    Afternoon all.
    I am looking at getting a towbar, and have seen a thread on here where a member had a Westfalia detachable bar (was a silver siggy, cant remember members name).
    My question is, are there holes and stuff already below the car to bolt into, or will I need to do a bit of drilling?
    Was thinking of getting this bar: http://www.westfalia-automotive.de/index.php?id=32&L=1
    from these people:
    http://www.towbarsdirect.co.uk/Vauxhall.htm
    But any further advice would be most welcome.
    you will need to get a stepdrill to go out to 40mm ( or a 40mm holesaw) and a 20mm holesaw.. the car needs the boot floorpan drilling in the premarked dimples to line up with the holes already in the chassis legs.. then use the 40mm holesaw to pass through the wiring to the rear electrical centre..
    Biggest tip i can give... Use the genuine VX wiring kit... its £40 and it's all plug and play... BUT be warned... to fit the bar you'll need to remove the rear trims from the back pillars/sides of the boot etc etc...so it's quite a big job to strip it, but not so big a job to fit the bar.
    Regular Member BIG NEIL's Avatar
    Oct 2007
    Back in Belfast!!!!
    the stripping out is the worst and most time consuming part.the rest of it is hamdy enough.i done my siggy about 3 months ago
    and as GSI said you will need about a 40mm hole saw.
    there is indents om the inside when you remove the trim of where the holes are.get a hairdryer to remove the soundproofing on the lefthand side.
    hope this helps
    Leicester
    When I did my Signum, I took the longer route of completely stripping the boot area, but boy did it make fitting the tow bar easier.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Default detachable towbar
    Quote Originally Posted by cheekylemon View Post
    Afternoon all.
    from these people:
    try www.Towequipe.co.uk i had the same tow bar as you are looking at its 100% invisable fitted at home by there mobile team, single elec's,relay, very good job would recomend to all £269 with a life time guarantee i think this has to have a yearly inspection for a nominal fee to keep the warrenty but its up to you ,the only thing if you do it yourself remember to remove the tar based lining where the plates sit inside the boot they do it with a hot air gun.
  1. Towbar fitting.
    By burbling1 in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2012, 16:59
  2. Towbar fitting
    By KTM Chris in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2012, 21:08
  3. Fitting towbar to Vectra C
    By Ste in forum Vectra C / Signum Car Chat
    Last Post: 30th September 2010, 15:17
  4. towbar fitting
    By derby4life in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2009, 11:04
  5. Fitting a towbar to vec c sri
    By speedo in forum Bodywork & Interior
    Last Post: 2nd May 2007, 07:38
