Thread: rattling sound
    Jan 2008
    WILLINGTON DERBY
    Default rattling sound
    Started up car this morning (2.2 petrol 2006 only 20k miles) to a rattling sound coming from the L/H side of engine, took it on a run to get the engine hot and its still rattling, taking it to the dealers in the morning to see what they think.
    Regular Member baztheman's Avatar
    washington tyne & wear
    hi kev m8 you say L/H side of engine is that from standing at the front of the car?
    here is 2 things that i have experienced standing in front of the car i found that i had a rattle it was the timing belt tentioner was braking up causing a rattle but my car is a 1.9 cdti diesel so you need to know if its a belt or a chain ,if its a chain they have been known to stretch and snap but im sure it was only on the 2.2 diesels.
    if the noise is coming from the L/H side from inside the car it may be the duel mass flywheel (the clutch system) depress and press the clutch to see if it goes away.
    if in doubt you could get a screwdriver out and use it like a stethoscope handle in ear and use the blade side to probe for maximum noise.
    hope you get it sorted m8,let us know what happens...baz
    if it's on the driverside of the engine, then it does sound like the timing chains..in which case get it looked at before it's driven far..
    a rattle on the passengerside is usually the flywheel...
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    Jan 2008
    WILLINGTON DERBY
    Quote Originally Posted by baztheman View Post
    Hi Baz
    Took it to the dealers this morning they confirmed it was the timming chain,
    Left it with them as their ordering one, should get it back Weds night / Thurs morning.
    Good job it happen when it did and not next weekend as I`am going up to Northumberland towing the caravan.
    Look out for me on Friday on the A1m.
    well im on the a1 from washington to newcastle 4 times a day taking/picking my wife up from work.
    i'm glad i was some help to you as it could have been very expensive if it had snapped (valves and head skim)
    dont forget to have the water pump changed at the same time (thats if its on the same chain) i have the 1.9cdti and i was told its good engineering to have it done as the stress of a new belt could cause it to fail premiturely.
    its always worth asking if its inline with the chain (anyone on here know?) if it is get it done as you will need the same work done all over again if it fails.
    happy driving m8....baz
    there are two chains.. replace BOTH...it's false economy not to..
    one chain drives the waterpump and balancer shafts, the other drives the camshafts..
    Apr 2008
    Bristol
    Does anyone know how often you should change the timing chain? I have a 52 plate vectra 2.2dti which has done 76k. When i took it into the garage this morning for it's mot, the mechanic told me that as it was a chain it does not need changing?
    Do i beleive him that is the question!?!?!?!?
  1. Rattling noise
    By Lozza in forum Engine & Drivetrain
    Last Post: 10th May 2012, 18:34
  2. still rattling!!
    By jofenan in forum Engine & Drivetrain
    Last Post: 19th January 2011, 23:25
  3. rattling
    By SilVectra in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2010, 20:53
  4. Rattling vvt.
    By mattDY57 in forum Engine & Drivetrain
    Last Post: 8th June 2009, 19:57
  5. Rattling Noise
    By rhodod in forum Vectra C / Signum Car Chat
    Last Post: 16th September 2008, 18:21
