Results 1 to 2 of 2
Thread: is there a electic primer pump in tank in 2.0dti
    Regular Member dervdoc's Avatar
    Co.Armagh
    Default is there a electic primer pump in tank in 2.0dti
    iv a 2.0dti veccy thats not getting fuel up to the filter is there an electronic primer pump in tank
    Oct 2007
    cornwall
    no there is no primer or lifter in the tank. im guessing you are wanting to try a force fuel up? get some brake cleaner and take off boost hose to the throttle and gently spray small amounts of brake cleaner into the throttle then crank engine (dont spray too much as engine will run on the cleaner alone) this should encourage the fuel to be pulled up from the tank, if not looking at pump problems
    jon
  1. fuel pump in tank noisy
    By dbgb25 in forum Engine & Drivetrain
    Last Post: 30th April 2012, 15:00
  2. NEED in tank fuel pump ASAP!!!!
    By bangty 1 in forum Vectra C / Signum Car Chat
    Last Post: 27th November 2010, 16:04
  3. 2.0DTi won't start - no fuel from tank...
    By phybrgj in forum Vectra C / Signum Car Chat
    Last Post: 15th March 2010, 17:37
  4. Diesel Pump Primer
    By FRANKA in forum Vectra C / Signum Car Chat
    Last Post: 22nd August 2009, 11:04
  5. 2.2 DTi in-tank fuel pump.
    By Ross DTi 2.2 in forum Vectra C / Signum Car Chat
    Last Post: 20th September 2006, 22:38
