Thread: slight chugging feeling
    Regular Member Morephun's Avatar
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    Default slight chugging feeling
    i am getting a brief chugging feeling sometimes when i put my foot on the accelerator and when i come off of the accelerator ... anyone any ideas
    desribe 'chugging ' mate???
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    1.Chugging;
    Loading up on alcoholic substance, power drinking.
    "that was crazy how fast he drank those pints! that's some power chugging!"
    Seriously, Clutch?
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    like a slight loss of power this more when moving slowly in traffic or accelerating away(not accelerating/decelerating smoothly)sometimes
    Regular Member baztheman's Avatar
    washington tyne & wear
    hi m8 try the cheap things 1st air filter and fuel filter (does if feel like its running out of fuel? (you didnt say if u have petrol or diesel) if its diesel drain the fuel filter incase it has water in there.
    have you any spanner light ? the egr valve is a prime canditate in lower pulling away speeds but normaly runs ok in higher revs or vise versa (if its happening across the full rev range it most likley isnt the egr.... baz
    it's a 1.8 petrol according to his profile..
    TBH, the 1.8 isn't at it's best at low RPM's...so it would chug if you're trying to make it pull at low RPM's or accelerating in too high a gear.. try giving it more throttle..
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    it is a petrol ,it seems to be worse when pulling away or moving slowly(but sometimes can be felt when driving along) air filter just got replaced 1 week ago...but recently the exhaust emmision light had been on and off a couple of times, no spanner light
    emissions light means dealer time..... if it stays on at any time then it's warning you that the CAT is in danger of being poisoned.
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    Thumbs up
    yes, it was the egr valve thanks baztheman...sorted now
    no probs m8,did you have it replaced? new for old or did you remove and clean it.
    even in petrol models they get crudded up and can be cleaned as the flap inside sticks,and in other cases the shaft on the control arm corrodes and it jams up which can be removed and cleaned with some very fine glass emery paper and a little wd40.... glad to be of help m8.... baz
  1. 150 chugging
    By skene in forum Engine & Drivetrain
    Last Post: 5th December 2012, 00:12
  2. My 2.2 is chugging going into 2nd gear:(
    By Jojow in forum Vectra C / Signum Car Chat
    Last Post: 15th August 2011, 20:40
  3. My 2.2 is chugging going into 2nd gear:(
    Last Post: 15th August 2011, 20:39
  4. Chugging 1.9cdti
    By thefibreguy in forum Engine & Drivetrain
    Last Post: 9th May 2011, 16:40
  5. The Tuning Box is off and Car is chugging??
    By VXR CDTi in forum Diesel Engine related
    Last Post: 13th November 2008, 16:23
2005 Opel vectra chugging
vauxhall vectra chugging
car chugging slightly
opel vectra slight chugging on high rpm
opel vectra petrol slight chugging on high rpm
slight chucking when excekerating in vauxhall vectra
vectra cdti chugging on acceleration
