Results 1 to 10 of 16
Thread: Brake wear warning won't go out...
    Leics
    Default Brake wear warning won't go out...
    I've got a bit of a problem on my 52 plate Vectra Club.
    The brake wear light came on, took it to KwikFit (probably a mistake!).
    Needed new front pads & discs, a new wear sensor, and a new caliper...
    Had the work done, but the wear light is still on.
    Bloke at kwikfit reckons it takes 100 miles or so for the wear light to go. I've now done 200+, and the light is still on. Was he telling me stories, or have I got some other problem?
    Cheers,
    PhilTr
    The bloke at Crap fit is talking rubbish if you put a new sensor on the light will go out straight away !!!!!!................They have either not put a new sensor on or have damaged it !!!!!
    Exactly
    Regular Member Steel's Avatar
    Sheffield
    Trim : SRI CDTI NAV
    Mileage : 202,800
    Quote Originally Posted by philtr View Post
    Probably just needed the dust blowing off the discs
    Leics
    Thanks everyone, that's what I suspected...
    Also, the LED display in the dash is flicking between the brake wear sensor, and low coolant level. The coolant level is fine, could there be some other problem?
    yep, if the coolant level is okay, then it sounds like the sensor in the tank is shot as well..
    Leics
    OK, thanks Mark. Is it possible to swap the sensor, or do I need to swap the whole tank? How hard a job is it?
    Is it possible that there could be another cause - it's just that both the warnings came on pretty much at the same time?
    Only reason I ask is I had some problems with the voltage regulator in the alternator for a few weeks while I was trying to convince the garage there was a problem. I'm just wondering if I've somehow managed to toast some of the electronics (hoping not).
    Thanks again!
    Phil
    Belfast
    Tenner says you didn't need a caliper or discs.
    Kwik-Fit are a bunch of hoods - I've seen people go in for a puncture and come out with 4 new (crap) tyres, and exhaust and new pads all round.
    Leics
    Quote Originally Posted by _ZS_ View Post
    Yeah you're probably right... the dust guards had gone on the caliper though...
    Wouldn't normally go to Kwik-Fit, but was about to do 400+ miles, and didn't have time to do any of the work myself.
    I shan't go back again, well, other than to put my boot up the git's arse who didn't fit the sensor correctly, and then fed me a lovely story about sensors taking 100 miles to bed in.
    What's betting that there's a 100 mile limit on the warranty?
    Thanks again!
    Phil
    change the coolant bottle..
    I strongly doubt the two faults are related..
  1. Brake wear sensors.
    By fastcarmanaic in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2010, 23:36
  2. Rear brake pad wear - a warning !!
    By blueboy in forum Handling & Braking
    Last Post: 5th October 2009, 19:59
  3. Brake wear warning light
    By spatch in forum Suspension, Wheels & Brakes
    Last Post: 4th September 2008, 19:28
  4. Brake pad wear warning light
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 21st August 2008, 08:48
  5. Brake pad wear alert
    By Pingu71 in forum Suspension, Wheels & Brakes
    Last Post: 12th April 2007, 10:27
vectra c brake worn light fault
52plate vectra pad wear light on
