Results 1 to 3 of 3
Thread: LED rear light fault
    Bournemouth
    Default LED rear light fault
    I've searched but had trouble finding a relevant thread, so apologies if this just repeats a common query...
    fitted red LED bulbs to the rear of my Signum yesterday and despite the fact they came supplied with resistors to mimic a standard bulb to prevent flashing and bulb-blown readings.... once all fitted and correct they blinked every 5 seconds or so....
    Is there a cure or am I destined to have standard bulbs for ever and ever?
    thanks all.
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    I think the Vec uses a pulsed power supply,the only way around it is to use brighter standard bulbs.
    member of the smoke patrol 230bhp+
    the word used for led bulbs in no
    but there is a way to do it,, but you need to spend about £100 on a canbus interface to run the rear lights
  1. Estate Rear brake light fault?
    By dv8 in forum Electrical & ICE (including SatNav)
    Last Post: 13th June 2012, 20:17
  2. 2.0 tdi fault light
    By vauxpower in forum Engine & Drivetrain
    Last Post: 22nd January 2011, 17:54
  3. fault light ??????????
    By iam2103 in forum Engine & Drivetrain
    Last Post: 3rd October 2010, 08:46
  4. rear light fault 2007 estate
    By ramsgate in forum Electrical & ICE (including SatNav)
    Last Post: 25th April 2010, 19:01
  5. TC AND ABS LIGHT Serious Fault
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 13th November 2008, 19:49
