Results 1 to 10 of 22
Thread: flat spot/hesitation
    Regular Member PeteRs's Avatar
    here or there
    Default flat spot/hesitation
    hi im getting a hesitation at 2k its very noticeable any ideas as its just started i also have the spanner light on when i start the car but goes out straight away car still runs fine apart from the flat spot its a 1.9 CDTi engine thanks
    Regular Member Gregg's Avatar
    Aug 2007
    Great Wyrley
    would the problem lie within the map you have had done possibly?
    might need looking at again
    Regular Member Steel's Avatar
    Sheffield
    Trim : SRI CDTI NAV
    Mileage : 202,800
    Spanner light coming on then going out means there is a fault code stored.
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    Is it the oil light? i had that until i changed the oil. it came on when i started and when i turned off. It looked like an oil can with a spanner
    Sheffield
    Trim : SRI CDTI NAV
    Mileage : 202,800
    I would have to check my handbook for just which light is which. If it's the one in the square display in the bottom of the rev counter it sholdn't come on unless something is wrong.
    here or there
    sorry had to go out dont know if its the remap it also feels down on power spanner light goes out straight away so not really bothered by it yet thanks
    putting my head in a noose.. who's remap is it?..
    Aug 2007
    Great Wyrley
    Pretty sure Pete had it done at the MIJ meet along with his rather nice exhaust system
    here or there
    yea MIJ did it been alright up to now
    Regular Member markm's Avatar
    Oct 2006
    Portsmouth
    If it was done at MIJ then the remap may be by V-Tune, had one done on a company Veccy and it was utter ****E !
    I bet my last quid it will be down to a very poor map,
    problems on our company Vec, low power under 3000rpm, very large flat spot at 1800-2000rpm if you give it to much throttle, if you drive it very softly it drives ok,
    if that sounds like you're car after the remap, then its probably the same ****e map they stuck on our company Vec,
    take it back, good luck mate, we had to wait a year for the refind by V-Tune .
  1. think i may have finally cured the famous flat spot hesitation,read on....
    By Richard.roberts in forum Engine & Drivetrain
    Last Post: 20th April 2014, 21:19
  2. Another Z19DTH flat spot/hesitation thread
    By Teapot in forum Engine & Drivetrain
    Last Post: 29th December 2012, 23:47
  3. Replies: 0
    Last Post: 8th August 2011, 16:39
  4. Flat Spot/Stutter or hesitation on 2006 1.8 VVTi SRI
    By Fireyfella in forum Engine & Drivetrain
    Last Post: 22nd November 2010, 08:30
  5. flat spot???
    By bobbyboy in forum Engine & Drivetrain
    Last Post: 25th January 2006, 00:00
vectra sri 1.8 hesitation at 3000rpm
