Thread: what rear brakes do the v6s have?
    Regular Member amar's Avatar
    London
    Question what rear brakes do the v6s have?
    hi all, I have upgraded my front brakes and am considering upgrading the rears in the future... (I no thery dont do that much) but my sri has solid rears and my saab has vented rather large rears... was thinking of finding a set of them... what do other models (vectrs) have at the rear?
    Regular Member Steel's Avatar
    Sheffield
    Trim : Sri
    Mileage : 198,500
    As far as I know they are all the same, the pads certainly were when I was looking through the parts listings for mine. If however the Saab 9-3 has vented rear discs I can see no reason why they wouldn't fit, what benefit you would gain under normal circumstances is unclear though because as you say, they don't do a great deal.
    if you were racing it might be a different story, my Firenza ended up with vented front and rear discs with twin servos and they were brilliant, the standard drum brakes used to go through a set of linings per meeting!
    You can make anything fit if you have a mind to (well almost)
    London
    well im sure if they fit my saab they will fit on the vectra... have to look at the rear set up more closely... if saab fitted them on the aeros they must be better...
    skelmersdale
    Smile
    I got a set from courtney for my gsi! They made me some grooved ones think they were £200 delivered! Not cheap but nice upgrade!
    All V6 engined veccy's have 292mm VENTED rear discs and its a simple mod to do all you need are new discs and caliper carriers as the calipers and pads are the same i did this to my 2.2 DTi as well as the 314mm fronts and it's made a HUGE difference
    London
    Quote Originally Posted by Drinky View Post
    Well thats what I wanted to hear... any idea how much the carriers are? were the back plates not too small?
    Not a clue how much the carriers cost as i pinched mine from my Elite while it's off the road you may have to trim a small bit from the back plates or bend them slightly back
    [Ex]Admin Duncan's Avatar
    All V6 engined veccy's have 292mm VENTED rear discs...
    ...as well as the 2.0T if you were possibly looking for a donor car amar.
    London
    so am i right in saying i only need calliper carriers and new pads/ discs...
    was thinking if the discs are thicker due to being vented shouldnt the callipers have to be wider so that they will fit inside with the pads?
    London
    looked at my saab rear brakes (apparently same as v6) they have the handbrake cable fitted to the calliper... not so on my vectra the cable goes to internal shoes i believe.... can anyone confirm what they have...
  1. need help for rear brakes
    By sharney2011 in forum Vectra C / Signum Troubleshooting
    Last Post: 8th October 2011, 18:20
  2. rear brakes
    By johnytaff in forum Suspension, Wheels & Brakes
    Last Post: 4th March 2011, 19:33
  3. Rear brakes
    By copperdock in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2008, 22:50
  4. scraping noise from rear. rear brakes? upgrade?
    By Whippy in forum Suspension, Wheels & Brakes
    Last Post: 5th March 2008, 01:26
  5. Rear brakes
    By dan1983 in forum Suspension, Wheels & Brakes
    Last Post: 22nd May 2007, 21:09
