Thread: brake pad wear indicator?
    Regular Member amar's Avatar
    London
    Question brake pad wear indicator?
    Hi all,
    I replaced my front brakes today with new 314mm set up from a saab 9-3 aero! The old front brakes were not worn out and the brake pad wear indicaor appeared fine it was not worn at all. Before replacing my front brakes the pad wear indicator used to come on intermittently and now its staying on.... My question is do the rear brakes have a pad wear indicator... I coulnt see one through the rear wheels!
    Regular Member Steel's Avatar
    Sheffield
    Trim : Sri
    Mileage : 198,500
    This has been covered before when I was proved wrong! My Vectra (05 model) has only one wear indicator on the nearside front wheel. I am led to believe some have rear indicators as well.
    the wear indicators are easily damaged and although it may look ok it is a wise move to replace it every time you replace the pads.
    London
    defo couldnt see one on the rear unless its fallen off and broken... lol maybe thats why the light is on...
    Sheffield
    Trim : Sri
    Mileage : 198,500
    It would only be on if the broken wire was touching metal and for it to be on constantly it would have to be screwed into the shocker, have you got any oil on your drive? lol
    London
    no oil leaking..lol guess i will have to order a new front one to be safe... an maybe i will take the rear wheels off to make sure there is not one there... thats if its not raining tommorow... lol
    do you know which side the rear one should be fitted too as i know there is only one front and poss one rear...
    London
    i know the front is on the passenger side... guessing the rear should be on the drivers side?
    Sheffield
    Trim : Sri
    Mileage : 198,500
    My guess is that there isn't an indicator on the rear at all, sounds like you have the same setup to mine, one indicator on the front nearside.
    London
    i think so... but will check the rears tommorow to confirm...
    [Ex]Admin Duncan's Avatar
    There's definitely no rear pad wear indicator, only the fronts - situated on the passenger side only, until they then dropped the feature on the facelift!
  1. Brake wear sensor put where?
    By kenp in forum Suspension, Wheels & Brakes
    Last Post: 28th August 2012, 23:33
  2. Brake pad wear indicator
    By cermi in forum Suspension, Wheels & Brakes
    Last Post: 3rd March 2012, 17:49
  3. brake pad wear sensors?
    By marwen in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2011, 12:01
  4. Brake Pad Wear Indicator
    By barachello in forum Suspension, Wheels & Brakes
    Last Post: 16th May 2011, 18:11
  5. Brake Pad Wear Indicator
    By Hendry in forum Vectra C / Signum Car Chat
    Last Post: 10th September 2007, 19:51
