Thanks Thanks:  1
Thread: Thumping sound, passenger side front on deceleration
    Regular Member sophos9's Avatar
    Norfolk
    Default Thumping sound, passenger side front on deceleration
    Hi, hope someone can help diagnose this problem...
    The Car:
    2003 Vectra 2.2 SRI petrol and the problem started yesterday.
    The Problem:
    From the front passenger side there is a loud thumping/knocking/rumbling sound on deceleration, the noise stops on decel if the brakes are applied. At one point, when I applied the brake, the ABS kicked in... When braking, car pulls straight and no vibes. Car on acceleration is pulling to the left.
    2 weeks ago, I changed the brake discs and had to knock the discs off with a hammer (as the locating screw was totally seized). I'm thinking that this fault is possibly related to the smacking of the discs....
    First thing I'm going to check is the road wheel bolts to 110nm, then the security of the calliper securing bolts.
    Any help diagnosing would be great!!
    Many thanks
    Larkhall
    It could be the brakes mate, as my old astra had a thumping coming from it when slowing down. According to the dealer it was warped discs......
    Norfolk
    Hi mate, thanks for the reply but I fitted genuine vx new discs 2 weeks ago, when braking there is no feedback through the steering column and the noise acutally stops when brakes are applied....
    Norfolk
    Yep, you know the answer already... loose road wheel bolts! All sorted now
  5. Thanks beavor-bob thanked for this post
  6. #5
    Nov 2013
    suffolk
    Vehicle : vectra 2007
    Trim : sri
    Engine : z18xer
    Thanks for your post - I had the same problem - & answer! NUTS LOOSE!
  1. whine from front passenger side
    By skip85 in forum Engine & Drivetrain
    Last Post: 2nd May 2012, 22:59
  2. Whining sound on deceleration
    By andreitone in forum Engine & Drivetrain
    Last Post: 19th May 2010, 06:05
  3. Clunking from Front Passenger Side
    By nick-v2.2 in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2009, 14:19
  4. Noised from Passenger Side Front Mirror, Please Help
    By S14RRJ in forum Suspension, Wheels & Brakes
    Last Post: 7th May 2008, 20:42
  5. Droning sound from front near side
    By Dio in forum Suspension, Wheels & Brakes
    Last Post: 18th April 2008, 00:07
