Thread: Boost
    Regular Member hudz's Avatar
    northern ireland
    Default Boost
    Does anyone know what the standard BAR of boost the 2.0 T runs and what the max safely it can be put up 2?Is it advisable 2 boost the pressure with a BSR stage 1 Remap!Has anyone fitted a digital boost controller 2 1!Sorry for so many questions at once,but any help would be appreciated as i'm considering all of the above,and would like ur advise before i blow her up!
    [Ex]Admin Duncan's Avatar
    Standard - 0.6 bar
    BSR Stage 1 - 1.0 bar
    BSR Stage 3 - 1.4/1.5 bar
    As for increasing the boost further with a Stage 1 installed, not sure how you plan to do it without throwing up errors and dropping the turbo into safe mode. Is that what you were planning to do with the digital boost controller? i.e. increase the boost.
    Why do you want to just increase the boost further when the Stage 1 has already increased it? Extra boost doesn't always mean more power and I can't help but think that as the boost parameters are set by the ECU software i.e. the remap all you're going to do is drop the turbo into safe mode.
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    As has been said on here very recently the BSR Stage 1 remap transforms the 2.0T without compromising engine safety. I have had no indications of increased engine stress as a result of the remap in fact if anything the car runs more smoothly, particularly if you do the airbox mod too. I'm sure others more technically aware will put your fears at rest.
    Edit: Sorry, misread initial post. Thanks Duncan
    South Central England
    12 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    The ECU has a nice little map of what the boost should be for x rpm and y load. If you play with it using a boost controller it may run fine at low loads and rpm but will probably drop into limp mode at higher loading. However, because the ECU does not have control of the Turbo, the effect of limp mode might not be very noticable, you don't loose all the power because the turbo is still boosting. So if you do said, you need to keep your eye open for the little amber light on the dash.
    northern ireland
    The blitz boost controller i got has a double solenoid,so i was advised by a mitsy expert 2 by pass the standard soleniods 2 fool ecu!I think he knows what he's talking about as his has 400BHP,but would like sum proper veccy advice,i.e from nutron and duncan etc,Recently fitted a bleed valve and accidently over boosted and ECU went into limp mode,luckily i have my own diognostics and can erase fault codes 2 put it back 2 normal!
    Advise would be appreciated,again!
    northern ireland
    Duncan,Nutron,anyone please!
    Sorry m8, not a scooby. I've never messed around with digital boost controllers. Nutron may have more input, but for somebody who's messed around a lot with their 2.0T, give rickyroo a shout. He no longer has his car, but he still visits the site. I don't know if he had a DBC or not, but maybe worth giving him a try.
    HTH
    northern ireland
    HTH
    Thanks duncan,advise most appreciated,i will be sure 2 send donation 2morrow,urs and others advise is priceless!
    P.S would send donation myself but i know sod all about puters and need the misses help,She's asleep,Sorry!
  1. No Boost/Irregular Boost
    By Seery_SRI in forum Engine & Drivetrain
    Last Post: 8th March 2011, 08:48
  2. boost flat spot boost????
    By lgtuk in forum Engine & Drivetrain
    Last Post: 7th June 2010, 16:14
  3. CDTI 150, 10k Boost De-Coked & New Boost Sensor
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 12:02
  4. no power off boost then savage boost at 2300rpm
    By 9tjc in forum Engine & Drivetrain
    Last Post: 2nd January 2010, 00:21
  5. cleaned boost sensor and still shows over boost
    By chowwie in forum Engine & Drivetrain
    Last Post: 14th November 2008, 09:23
