Thread: Just one more suspension question
    Regular Member craigmerry's Avatar
    Jan 2008
    midlands
    Default Just one more suspension question
    When undoing the bit from inside engine bay(torq/star nuts) do i need to remove all 4 or just the middle one ? Haynes say all 4 ?
    on the struts?...
    you undo all 3 outer torx bolts and remove the strut from the car... then , WHEN THE SPRING IS COMPRESSED, remove the inner big nut....
    DON'T DO IT ANY OTHER WAY.....
    Haynes manual.....doesn't sound like it's very clear does it..
    Regular Member hudz's Avatar
    northern ireland
    If u take them all out,you'll have springs flying all over the place!
    and taking yer head off.... don't underestimate how deadly these are if they fly loose..
    Jan 2008
    midlands
    on the struts?...
    The haynes rear how to is perfect, front just trickier i think. So i undo the 3 outer ones, undo bottom nuts, then remove the whole lot. Put the compressers on and remove the middle one. And refitting is the opposite of removal yes ?
    northern ireland
    You got it!
    Jan 2008
    midlands
    Quote Originally Posted by hudz View Post
    You got it!
    Fingers crossed then , just watch out for an urgent help thread tommorrow . Got 6 hrs before my bro finishes work anyway, hopefully won't need to ask my little brother for help
    northern ireland
    Just make sure spring is well compressed and is free 2 move about before u remove top nut in suspension unit,damper piston will turn as u undo top nut so be sure 2 stop from turning!Good luck,it's handy enough!
  1. Suspension Question
    By 9171joshua in forum Suspension, Wheels & Brakes
    Last Post: 7th September 2010, 09:58
  2. Suspension question??
    By colalowe in forum Vectra C / Signum Car Chat
    Last Post: 10th September 2008, 20:05
  3. suspension question
    By craigmerry in forum Vectra C / Signum Car Chat
    Last Post: 3rd April 2008, 17:58
  4. suspension question. ???????
    By kev bux in forum Suspension, Wheels & Brakes
    Last Post: 9th March 2008, 15:55
  5. suspension question
    By grattygruff in forum Handling & Braking
    Last Post: 13th July 2007, 21:09
