Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: aftermarket parking sensors
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    Default aftermarket parking sensors
    hi all im looking at buying some of these;
    http://cgi.ebay.co.uk/Rear-Parking-R...QQcmdZViewItem
    but need to know how they wire up before i buy them? has anyone else had these or similar if so if you could described how you wired them it would be a great help! thanks in advance
    Great kit i have this one on my SRi and its a doddle to fit two wires and it's up and running live feed to the reverse light and an earth !!!!!!
    Feb 2007
    Quote Originally Posted by Drinky View Post
    cheers drinky not that electronically minded mate how do i fix the wires from the sensors to the reverse and earth on the loom of the light?
    Pop into halfords and get a couple of scotch blocks and use them simple pop the wires through and give them a squeeze with a pair of pliers job done !!!!!
    If you can make it there is a bit of a get together near ellesmere port this sunday and i will gladly wire them in for you no problem !!!!
    Sunny Dartmoor
    Those are the one's i've fitted to my car,great kit and a doddle to fit,here's a pic of how they look............
    Feb 2007
    cheers for the pic glen are the holes marked on the inside like ive been told? cheers for the offer drinky but sadly cant make it!
    Regular Member jontymo's Avatar
    Feb 2007
    Huddersfield
    How easy is it to take the rear bumper off?
    jontymo
    Sunny Dartmoor
    Holes are marked,and bumper is very easy to get off,just follow the How2,good luck,don't forget the pic's when done.........
    Feb 2007
    where did you place the thing that make the noise to tell you how close you are?
  1. fitting aftermarket rear parking sensors , best way to get into boot?
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 10th December 2012, 11:08
  2. fitting aftermarket rear parking sensors
    By taffy bhoy in forum Electrical & ICE (including SatNav)
    Last Post: 9th September 2011, 19:45
  3. OEM Parking Sensors with aftermarket module
    By djr69uk in forum Electrical & ICE (including SatNav)
    Last Post: 24th March 2011, 19:32
  4. Aftermarket Parking Sensors
    By ABS_Mouse in forum Vectra C / Signum Car Chat
    Last Post: 3rd December 2010, 21:21
  5. Vauxhall Aftermarket Parking Sensors
    By Craig Rogers in forum Electrical & ICE (including SatNav)
    Last Post: 28th May 2008, 14:18
