Thread: tech 2 code ?
    Regular Member tankman's Avatar
    Feb 2007
    NORTHUMBERLAND
    Default tech 2 code ?
    does anybody know what the tech code p0460 fuel circuit malfunction mean's and is it a replacement part. (i'm stumped) car is idling awful and is the same when driving any clue's guy's help
    Regular Member Steel's Avatar
    Sheffield
    Trim : Sri
    I have a DTC library that comes up with P0460 Fuel Level Sensor A Circuit Malfunction. This is from an OBD II Generic code table. Autodata comes up with the same suggesting a wiring fault to the fuel tank level sensor as being a possible cause.
    Feb 2007
    NORTHUMBERLAND
    this wouldn't cause the bad idling would it.3 other codes come up as well p0110 so i replacethe mass meter,p0301 replace the plugs and coil pack,po170 don't know what this is.
    Quote Originally Posted by Steel View Post
    Sheffield
    Trim : Sri
    P0170 OBD Generic comes up as Fuel Trim Malfunction (bank 1) which could be (according to the Autodata bible) Intake leak, AIR system, fuel pressure/pump (which could throw back to the previous answer possibly), injectors, EVAP canister purge valve or HO2S whatever that is!
    HTH
  1. tech grey paint code
    By trucker in forum Insignia car chat
    Last Post: 29th May 2010, 19:24
  2. Tech 2 code readers
    By GenVectra in forum Vectra C / Signum Car Chat
    Last Post: 27th July 2009, 13:38
  3. tech 2 code needed
    By glynn in forum Electrical & ICE (including SatNav)
    Last Post: 7th June 2007, 09:15
