Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: Can i get Front Drilled and Grooved Discs
    Question Can i get Front Drilled and Grooved Discs
    Can you help?
    Im after a set of Drilled and Grooved discs for my 2003 , 1800LS.
    Does anyone have any idea where i can get them from please.
    Have searched the net but just seem to be gettin results for vec B.
    Many thanks micky..
    Vehicle : i500
    Trim : i500
    Engine : V6 3.0CDTi
    have a word with drinky he may know some where
    I've also been looking for big brakes that are grooved or drilled, but I've not been very successful so far. I may have to see if the VXR brakes fit our veccy's then see if Drinky can drill them for me. I've not asked him yet, so he may say ferk off.
    SCOTLAND
    I know you can get rossini discs but they are just grooved. you can get them up to 308mm as well. got good reviews in total vauxhall recently
    308mm? Is that the size fitted standard to GSI's???
    Regular Member Beavis's Avatar
    Blackburn Lancashire
    rossini do the front and back discs check out the address
    www.carparts-direct.co.uk
    regards Steve
    Those prices seem quite reasonable to me. Are they?
    I'm after the biddest brakes i can get. I believe the VXR discs are 345mm is this correct, and will they fit our veccy's, anyone?
    don't know if the vxr brakes will fit but can't see why not,i will be getting some of the rossini discs soon as my car will fail its first mot on the discs that are on at the moment(badley worn!!) so when i get them will let peeps know what they are like
    regards Steve
    Piccies mate. We need Piccies ;-)
    SCOTLAND
    the rossini ones have the name etched into disc as well so you know when they are worn. 308mm is the size on the GSi alex. I would say vxr will fit if you have 18"s or 19"s but remember you would need to get calipers as well.
    i am thinking of this or ebc grooved 309mm discs / rossini discs with greenstuff pads for front and same for rear (smaller discs though) then maybe getting some braided pipes and dot5 brake fluid.
  1. Drilled and grooved discs
    By sla002 in forum Vectra C / Signum Car Chat
    Last Post: 15th September 2011, 20:27
  2. Cheap grooved and drilled/dimpled discs
    By Ben Chiles in forum Tuning
    Last Post: 24th February 2011, 16:44
  3. Drilled and grooved front discs
    By soulie in forum Suspension, Wheels & Brakes
    Last Post: 23rd January 2010, 20:53
  4. Drilled and grooved front+rear discs
    By mucklestone in forum Handling & Braking
    Last Post: 17th August 2009, 19:59
  5. drilled and grooved brake discs
    By Beavis in forum Vectra C / Signum Car Chat
    Last Post: 30th November 2005, 13:47
