Thread: Airbox
    Larkhall
    Default Airbox
    This may sound silly but could the airbox mod cause any problems? The reason i ask is that the car has gone into limp home mode twice since putting a k&n filter in and removing the cone part from the hose.
    One of the guys i work with asked if this could be the cause, and it got me thinking........
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    ****** modern cars with engine management, all those flippin sensors.
    Twas easier in my day, knew one part of a distributor from another, ah the days of hitting starter motors with lump hammers..............fond memories............
    Sorry, no help from me eh....................
    get back to listening to guns n roses now.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Shouldn't cause any issues.
    Tam did you disconnect the battery when you removed the cone part?
    Apparently you need to, to let the ECU 'learn new parameters'.
    Gazza4
    Larkhall
    No, i just took it off and put the new filter in and away i went!
    The car felt a bit quicker off the mark but it's been feeling quite sluggish the past few weeks
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by T4M View Post
    Tam before you disconnect the battery make sure:
    - You have the radio code and manuals for Vectra and Radio
    - All Windows are up
    Disconnect the battery and then re-connect it after 15mins.
    Enter the code when radio ask you to - refer to manual for help in activating the radio.
    Refer to manual for information regarding the Window activation.
    Gazza4
    Larkhall
    That sounds quite complicated.................. and easy for me to mess up lol
    The car is getting a diagnostics test next week to try and find any problems. Will disconnecting the battery and resetting the ECU help any?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    May do - I'm not lookin forward to it either and I always say if you are not confident do not attempt it but it is simple anyway. Think your ECU needs to learn to expect a slightly higher airflow.
    Gazza4
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Tam, do not disconnect the battery the ECU will "learn" the new parameters within roughly 50 miles.
    What else have you done to it?
    Make sure you have not disturbed any connections when you did the mod. Have you tightened and connected all the hoses properly?
    Only once you have double checked all of these should you take it to a dealers to have the codes checked.
    3.2 v6 Signum and loving it
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by Johnsdutton View Post
    TAM Listen to Johnsdutton, then he seems more clued up to your problem!!
    I'm no lookin forward to my Airbox mod!
    Gazza4
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    There is no need to get it checked out just for doing the airbox mod. the Ecu will correct itself as it works along similar lines to the trip computer, which works out it's averages over the last ten miles. If the car was running OK immediately after the mod was done then the fault will almost certainly be somewhere else.
  1. Airbox mod.....part deux!!! (rip off of VXR280 airbox mod)
    By paul_sri150 in forum Diesel Engine related
    Last Post: 30th January 2012, 22:50
  2. Airbox Mod!!
    By R-ford_Vec_C in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2010, 14:15
  3. airbox mod
    By andy_hare in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2010, 14:29
  4. Airbox mod(But Why)
    By stanian in forum Petrol Engine related
    Last Post: 7th May 2009, 09:49
  5. Help with the airbox mod?
    By strothrc in forum Diesel Engine related
    Last Post: 9th April 2009, 15:10
