Results 1 to 10 of 11
Thread: fuel
    Feb 2008
    Wirral cheshire
    Default fuel
    Hey guys i know you have probably been asked before, but i just started using shell v power today. Am i actually gonna be able to tell the difference from normal fuel is it worth the extra 7p a litre???
    Oh an admin got me vectra c sticker today put it on rear window
    Full Member
    Jun 2007
    N/A
    7 Post(s)
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    These 'enhanced fuels' will make very slight improvements because they actually clean the engine - well injector nozzles anyway and burn alot easier meaning slightly less fuel needed but I personally believe your being charged to make your imagination work harder!
    Gazza4
    Feb 2008
    Wirral cheshire
    lol so you reckon it wont make much difference in mpg in the 2.2 sri???
    Regular Member lilangel's Avatar
    Feb 2008
    bucks
    i use the tesco 99 and can deffo tell the difference on my 3.2 v6. not really mpg, but more responsive
    Feb 2008
    Wirral cheshire
    yeah i've heard good things about that, but around here i think its about 1.14 when v powers only 1.10 which is weird
    To be honest, as time goes by and the fuel gets more expensive, the difference in cost between normal and 'super' stuff stays the same, so percentage-wise it's costing less and less...
    Regular Member petel's Avatar
    Nov 2007
    bristol
    I run mine on tescos 99 and am convinced i am getting better fuel consumption and car feels better,even if its in my head it makes me feel better so well worth the cost imo!!
    Feb 2008
    Wirral cheshire
    ay also heard that if you upgrade to iridium plugs that combined with 99ron fuel makes a difference in your mpg. I'll stick with it see how it goes, only on 2nd fill up so far
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    TBH it will most likely be the spark plugs giving you the extra mpg, using a decent set and aligning them correctly will improve the performance very slightly. i personally think the v power is a load of cr@p, if you keep your injectors clean, with a bit of redex for example, and keep your oil good then that will make the difference. Also the money you save by using regular fuels will pay for this!
    I used v power diesel for a while and didnt notice any difference so switched back to regular diesel. just kept my injectors clear. Best way although not advised for regular activity is to run the fuel very low, whack in a whole bottle of redex and pretty much run the fuel out. I did this and it worked a treat, mechanic friend gave me this tip!
    Regular Member shippers's Avatar
    Jun 2007
    driffield
    Im sure i get better perofmance and around 20 - 30 miles more on v-power than 95 ron....I notice more wheel spin with the v-power and i get a nice pop and bang from the zorst when changing gear
  1. 2.2 direct fuel pump and fuel pressure regulator
    By w111y in forum Engine & Drivetrain
    Last Post: 11th July 2012, 22:12
  2. Fuel housing sensor/fuel temp senser a
    By sri adi in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2010, 10:15
  3. high pressur fuel pump and fuel regulator ?
    By simplesi in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2010, 12:23
  4. Fuel pressure sensor/fuel pump failure list following Watchdog investigation.
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 13:18
