Thread: Front Parking Sensor Position
    Regular Member Vectra-Dog's Avatar
    Birmingham
    Default Front Parking Sensor Position
    I am about to fit an aftermarket parking sensor kit to my 06 Estate. I have found the rear sensor positions elsewhere on this site. I would like to fit the front sensors in the factory positions.
    Does anybody know the factory dimensions or if the facelift bumpers are marked on the inside with the positions.
    I am not to worried about having the bumper of as i have done the Signum surround upgrade and it comes off within 10 Mins.
    Full Member Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    i'll be doing mine as soon as my brother is about to help me, my bumper has the marking on the inside, i know for sure as i used these marking to get the ident code for the brackets
    Birmingham
    Thanks Pete,
    Hopefully mine will have them then. Thats going to make things a bit easier!
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Engine : 3.0 TDV6
    Mileage : 3023
    No Probs, The only thing is that i replaced my sri xp front bumper with a vxr one and they only come with the Parking sensor and AFL washer position marked on them as they don't do a vxr bumper with them cut out... also the proper factory brackets have the angle set, the 2 outer ones are different to the ones either side of the number plate, If your sensors could fit into them they would look factory fitted..
    Regular Member Damian's Avatar
    Market Drayton
    Quote Originally Posted by Vectra-Dog View Post
    Have you got a link to the kit you are fitting, do they come with a switch so they are not on all the time, or are the activated after activating the rears
    Regular Member shan's Avatar
    Don't drill the hole's from the back mate.
    Drill a small pilot hole from the back and then use a holesaw from the front. You dont want to damage the bumper they arn't cheap.
    Just a tip i'm not telling you how to suck egg's
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    or get yourself a bumper with the factory fit mounting brackets
    http://forum.vectra-c.com/showthread.php?t=45152
  1. help needed with front parking sensor wiring
    By montyfert in forum Electrical & ICE (including SatNav)
    Last Post: 5th August 2012, 13:23
  2. front parking sensor switch
    By nokiaman1978 in forum Electrical & ICE (including SatNav)
    Last Post: 12th August 2011, 00:24
  3. genuine front parking sensor install help
    By Caveman_nige in forum Bodywork & Interior
    Last Post: 4th April 2011, 17:25
  4. Front parking sensor control
    Last Post: 31st January 2010, 21:35
  5. Parking sensor position
    By Guyver1 in forum Vectra C / Signum Car Chat
    Last Post: 28th May 2009, 20:39
