Thread: suspension too hard
    Regular Member PeteRs's Avatar
    here or there
    Default suspension too hard
    hi i recently lowered the car by 40mm with PI springs its too hard its like the shocks are compressed too much as i dont get any bounce when i go over bumps or manholes the car moves sideways so thinking either put standard sri back or change shocks dont want to waste money on B4's if its going stay the same all of the bushes or drop links are ok dont know what to do thanks
    [Ex]Admin Duncan's Avatar
    If you've lowered 40mm i.e an extra 25mm from the SRi suspension then you really need to do the dampers too so it's all matched up - the dampers will be shorter basically.
    Even then, you're going to have to accept that the ride is still going to be a fair bit firmer than the standard SRi suspension was. Whether you can live with that is a personal thing. Is there anyone near to you that's got the full -40mm kit (springs and dampers) that you could get a ride in first?
    Regular Member mushy2007's Avatar
    Liverpool
    As duncan said you need the full kit mate, the uprated dampers keep the springs in line so to speak
    Belfast
    You may as well have put in a couple of paper clips for all the good Pi are. Crap things.
    here or there
    are the B4's shorter or is there another set i need
  1. Suspension knocking? Will Vec c suspension fit a Siggy?
    By shane5861 in forum Handling & Braking
    Last Post: 6th May 2011, 14:20
  2. DTi suspension v CDTi suspension
    By jamesy in forum Vectra C / Signum Car Chat
    Last Post: 3rd March 2011, 19:02
  3. how hard are these to do
    By booker413 in forum Vectra C / Signum Troubleshooting
    Last Post: 20th June 2010, 14:23
  4. Replies: 5
    Last Post: 21st March 2010, 12:34
  5. Hard suspension??
    By Avenged in forum Suspension, Wheels & Brakes
    Last Post: 4th January 2009, 17:18
