Thread: Battery Terminals
    Feb 2007
    GREENOCK
    Default Battery Terminals
    Should you grease your battery terminals and what should you use ?
    Sunny Dartmoor
    Yes you should,any sort of grease ahould do,i use a multi-purpose grease have done for years..............
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Vaseline is the best thing for battery terminals to prevent corrosion.
    Regular Member NealM's Avatar
    Mar 2007
    Cheshire
    Vehicle : Pre-Facelift
    Trim : LS
    Engine : 1.8 Petrol
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Halfords do a battery terminal spray which is quite good,also protect any other visible earth points.
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Should be done/renewed as needed as part of a service, if it's done properly, surely? The door hinges should also be greased as part of the service schedule.
  1. battery wiring block next to battery 150tdci - HELP
    By jameslunt in forum Electrical & ICE (including SatNav)
    Last Post: 2nd July 2012, 07:19
  2. Battery Light ON - 14.1 volts at battery
    By snapsnap in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2011, 13:55
  3. cd30 wiring terminals.
    By jrh1 in forum Electrical & ICE (including SatNav)
    Last Post: 15th September 2009, 18:25
  4. Battery Terminals
    By bigcraig in forum Vectra C / Signum Car Chat
    Last Post: 12th July 2008, 09:08
