Thread: CD70 locked
    Regular Member kantimpalo's Avatar
    Feb 2007
    Spain
    Default CD70 locked
    I have bought a CD70 with CID but this is not "unpaired".
    I have the Reg Car and the radio pass.
    Is possible unlock this radio?
    Thanks.
    Nr Cardiff
    I'm guessing it will need to be Tech 2'd.
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    if the CD70 and the CID came from the same car, there is a chance it will work.
    If they are from a different car and were not unpaired, even Tech2 will not bring a solution.
    It is not possible to have a 'radio pass' , the CD70 does not have one... the car code is needed to pair or unpair it
    Feb 2007
    Spain
    Quote Originally Posted by sig63 View Post
    Both are came from the same car.
    I believe that i have chance.
    Belgium
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Quote Originally Posted by kantimpalo View Post
    as long as you don't have the original car kit (UHP) or ECC, because they are also linked to the CID..
    Feb 2007
    Spain
    I don't have the car kit.
    What's is the ECC?
    The Electronic Climate Control?
    Feb 2007
    Spain
    If you have the car code is possible to pair the unit?
    Does GM can take the form of unlocked?
    I know a guy in GM Spain who could help me.
    Belgium
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    What's is the ECC?
    correct
    a unit can only be paired if it has been unpaired;
    unpairing (reseting) is only possible in the original car (VIN and car security code are used);
    I suppose that other forms of unlocking are technical possible, but I'm not sure if Opel wants/likes to do that.
    Feb 2007
    Spain
    correct
    I have the VIN.
    Is possible to ask the car security code to Opel having the VIN?
    Thanks for your help, Sig63.
    Feb 2007
    Spain
    correct
    I have also the ECC of the original car.
    With this the screen will work correctly?
    Thanks.
  1. Locked out of Car!!
    By Telly Addict in forum Bodywork & Interior
    Last Post: 14th January 2013, 02:54
  2. They want locked up and never to see daylight again
    By marc vectra sri in forum General Chat
    Last Post: 29th June 2012, 18:04
  3. been locked out
    By rob 2.2dti in forum General Chat
    Last Post: 11th December 2011, 10:48
  4. CD70 Navi locked in Upgrade mode
    By marksut74 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd August 2009, 22:30
  5. locked threads
    By billyyoung in forum General Chat
    Last Post: 30th October 2008, 20:04
