Results 1 to 10 of 16
Thread: auto box query
    aldershot
    Cool auto box query
    hi just about to pick up a 04 2.2 sri auto reading some of the posts there appears to be a problem with the cooler seals?
    I have the following questions :-
    1, is there any way i can tell if this work has been done?
    2, the guy told me its a sealed box? is this the case or can I check and change the transmission oil?
    TA
    Regular Member mushy2007's Avatar
    Liverpool
    You can check with VX for the mod's and the gearbox is sealed but can be drained and refilled if needed.
    The box should only ever need topping up apparantly as they class it sealed for life.
    gsi3.2 might offer some good info too
    aldershot
    thanx for that is there any way of knowing whether it needs topping up cant see a dipstick, although other pepole with gsi's appear to have one and change the oil are they different boxes
    Liverpool
    Sorry for the confusion gsi3.2 is a member and works in the technical department! pm him for more info if he doesnt come along soon
    11 Post(s)
    Quote Originally Posted by chinese taxi View Post
    There is no dipstick on these boxes. Also I believe if any topping up has to be done, the required amount is done electronically or maybe the fluid has to be weighed. Can't remember which. As already said though, these boxes are sealed for life.
    aldershot
    ok guys sorry for being so dumb!!
    sorry to correct you matey, but there is a dipstick....
    it's green in colour, found to the left of the oil cooler pipes when veiwed from above, and secured with a 12mm hex bolt.... two sets of markings, for hot and cold levels..
    Also, they are not sealed for life.. there is a drain hole, and a filler...if the car is used as a cab, police vehicle or tows a trailer/caravan then it should be flushed and have the fluid changed every 60,000 miles..
    Liverpool
    See told yer he'd be here soon! ha ha
    yeah, still around, but spending a lot of my forum time on organising the irmscher run at the mo..
    aldershot
    thanks for that thought that was the case looking at auto data it says it should be changed at 90km , will look for the dipstick saturday before I part with the redies.any body recomend any particular transmission oil?
  1. Auto Wipers and Auto Headlights
    By skip85 in forum Electrical & ICE (including SatNav)
    Last Post: 25th November 2012, 01:12
  2. Help needed - Auto dim mirror & poss auto wipers
    By mark_647 in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2009, 01:09
  3. Auto wipers.. and auto dimming mirror ?
    Last Post: 28th January 2009, 01:24
  4. Auto Dimming Mirror/Auto Wipers
    By lofty in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2008, 21:42
  5. Vectra 1.9CDTI 150 Auto v 2.2Direct Auto
    By mattr in forum Vectra C / Signum Car Chat
    Last Post: 19th November 2007, 19:16
