Thread: Hollow Sounding Knocking???
    Regular Member ChrisFox's Avatar
    Feb 2007
    Northampton
    Default Hollow Sounding Knocking???
    I have a REALLY annoying knocking coming from the front of the car, the knocking has a hollow sound and sounds like it could be the exhaust or radiator
    It only happens when the car jolts over bumps or hits pot holes
    Any ideas, as I have checked under the bonnet and cannot see anything obvious
    HELP!
    Mileage : 000
    There was an issue with the radiator making a noise when you go over bumps, changing the radiator mounting bushes should stop the noise if that is where it is comong from. It is possible to be a susspention bush too, anti roll bar bushes are known to "play" up.
    Regular Member grumpano's Avatar
    North West
    Could be a broken spring mate..
    Mileage : 000
    Quote Originally Posted by grumpano View Post
    When I had springs brake on Larisa,s Vectra B they tend to rattle, I must admit it does sound like an exhaust clamp being loose though.
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Possibly ****ed drop links, Take a wheel of & feel for play, to do a proper check of them you really need to remove at least one end..
    Dean
  1. hollow thumping noise & split drive shaft gaiter
    By cavalier_attitude in forum Suspension, Wheels & Brakes
    Last Post: 2nd August 2012, 14:41
  2. Vectra - Hollow Car?
    By george1987 in forum Vectra C / Signum Car Chat
    Last Post: 15th October 2010, 11:00
  3. engine not sounding right on my dti
    By steven_armit in forum Engine & Drivetrain
    Last Post: 2nd June 2009, 19:51
  4. Car sounding a bit rough 3.2 V6
    By korlinski in forum Vectra C / Signum Car Chat
    Last Post: 7th August 2007, 16:54
  5. Horn not sounding right
    By Cheeky_B in forum Vectra C / Signum Car Chat
    Last Post: 7th July 2006, 23:02
hollow sounding engine inaignia
