Thread: boost presure control
    Apr 2008
    CAMBUSLANG,GLASGOW
    Default boost presure control
    hi everyone im a newbee here so not sure if posted on right part
    i have a vectra 2.0 dti. 2003 on saturday i was going up an incline not much of 1 right enough, however whilst accelerating my car made a noise much like a dump valve sound and then whent into limp mode and would not go over 40 mph. i pulled into side and restarted it after about 300 yrds a spanner sign came on. i pulled in again and restarted car it has never came back on. my friend has a professional code reader and it states the following: P0234 BOOST PRESSURE CONTROL POSITIVE DEVIATON.
    can anyone tell me what this means. he cleared the code and car drives fine but i di feel a slight lack of performance (not sure if i just imagine it)
    many thanks for all replies
    graham
    [Ex]Admin Duncan's Avatar
    Moved this to it's own thread for you.
    Sound like the all to familiar split boost hoses problem on the 2.0/2.2. DTi. Have a search for 'split boost hose' and you'll find a few threads, and check over all your boost hoses carefully for small splits.
    Apr 2008
    CAMBUSLANG,GLASGOW
    Default boost control
    thanks duncan for posting in correct place sorry for the slip up
    graham
    No worries - just thought you'd get more people looking/replies with it in it's own thread.
    Apr 2008
    CAMBUSLANG,GLASGOW
    Default booster presure control
    well duncan i just joined and your advice was spot on i went out lifted bonnet and started inspecting the hoses. and yes i found it. the hose at front of car just at radiator was the one it was split just under the engine cover. what a result thank god for very good forums. many thanks for your help
    graham
    Excellent! - sorted. - and from memory that's the hose that is the one that usually goes.
    You just need to get the new one form the dealer - they modified the hose to be thicker/stronger to, hopefully, reduce the chance of it happening again. Your wallet will take a wee bit of a bashing though as the part you need is, from memory, a couple of hoses combined. I think it's around £120(?) - that figure seems to stick in my head, but guys that have actually had to buy one can confirm, or you may find it mentioned in the other threads.
  1. boost presure
    By grump in forum Engine & Drivetrain
    Last Post: 20th October 2012, 18:33
  2. boost control solenoid
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 12th October 2012, 13:45
  3. Boost control with actuator arm
    By tomo41 in forum Vectra C / Signum Car Chat
    Last Post: 22nd July 2011, 08:24
  4. presure boost valve
    By reeseandellie in forum Engine & Drivetrain
    Last Post: 18th April 2010, 03:56
  5. boost presure valve
    By reeseandellie in forum Electrical & ICE (including SatNav)
    Last Post: 15th April 2010, 20:21
boost presure
