Thread: Moulded wheel trims
    Regular Member Dave1.8's Avatar
    Oct 2007
    Ellesmere Port
    Default Moulded wheel trims
    I am thinking of taking my molded wheel trims off later, to clean them. I see one of the wheel bolts holds the trim on, but do they just pop off after that? thanks
    Oct 2007
    Ellesmere Port
    I'm talking about the steel wheels that are supposed to look like alloys. Anyone know if they just pull off?
    Sunny Dartmoor
    Probably,most just pop off,have you got any pic's??
    Oct 2007
    Ellesmere Port
    They are like these ones http://forum.vectra-c.com/showthread...tructure+wheel I have done it now, I took them off and washed them in the sink at work. They look like new now.
    Regular Member GCM's Avatar
    May 2007
    Coventry
    Hi, I have an 07 Vectra Exclusiv and thought that the bolts retained the wheel trims but they don't. Once the nut covers are removed they can be pulled straight off the wheels. I have done this a few times now for cleaning. HTH
    Oct 2007
    Ellesmere Port
    I tryd that, but when you push it back on, the flange on the wheel bolt dosn't go on the outside of the trim again. So it will not hold the wheel trim on anymore if you do that. One of the bolts has a flange on it, or at least it should do!
  1. Vauxhall wheel trims
    By Marky in forum Vectra C / Signum Car Chat
    Last Post: 16th September 2011, 13:10
  2. New shape wheel trims
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 13th December 2009, 00:32
  3. Steering wheel trims
    By parsco in forum Styling
    Last Post: 26th March 2009, 17:57
  4. wheel trims
    By guiggsy in forum Vectra C / Signum Car Chat
    Last Post: 12th January 2006, 09:37
