Results 1 to 10 of 13
Thread: start up noise
    Apr 2008
    cambridge
    Default start up noise
    Hi, first time on this so we shall see what happens!Got a 3.2 V6 auto 54 plate 60,500 miles on it. Every morning on start up i hear a knocking noise from engine bay lasting for maybe 10 seconds max, then it goes. Doesnt happen any other time during day when i start, only first start of day.Cant re create the noise to show mechanics. Very worried!
    Apr 2008
    cambridge
    Hey! didnt think it would take this long.
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Is it a Knock or more of a rattle ?
    If it only happens after an overnight stand then it is due to the oil draining back to the sump fully, Engines are generally a bit rattley 1st thing until the oil has circulated..
    If there is a knocking & this is not the normal overnight stand engine noise being generated, A good competant mechanic will be able to diagnose, can you not leave it with the garage for them to hear it 1st thing ??
    Dean
    Apr 2008
    cambridge
    thanks for that, think its more of a knocking noise. someone who heard it said it sounds like a big end noise. Does a big end noise only happen when its cold? I could leave it a garage over night for them to hear first thing, just wanting to hear what others think it might be before doing that.thanks
    Full Member Big Sig's Avatar
    Big ends can notmally be heard all the time I think. Although quieter than when first started.
    Regular Member poves's Avatar
    lancashire
    Mine makes some funny noises on startup also , it soon calms down though , just one of the traits of the 3.2 I think cos the engine is bang on , 37000 miles
    Apr 2008
    cambridge
    Thanks for that. its been doing this for a couple of months now, and not getting worse. Just want to put my mind at ease that its not anything big!
    Nov 2007
    Staffordshire
    Quote Originally Posted by Howdey View Post
    If a Big end knocks on startup you would expect it to keep knocking although it would get quieter but go deeper in sound/tone,
    Big ends that rattle at startup due to shell wear or crank wear don't normally re appear until it has stood over night Etc. It's the Oil/pressure filling the gap
    It's not Piston Slap is it ?? Although you normally hear of the engines that are susceptible to that.
    Dean
    Apr 2008
    cambridge
    Piston slap? wouldnt know what it is! The noise is really quite loud, but after a few seconds goes completely. There is no other obvious signs. Car runs well.Forgot to mention that it had a prof gas conversion 2yrs ago, and done 40K since, but the gas system doesnt kick in until the engine has warmed up, generally within 1 mile of start up. I run the car on petrol for 50 miles or so once a month, rest of the time on lpg.
    Nov 2007
    Staffordshire
    Piston slap is a Kind of GRrrrr Mixed with a Knock at the same time, Although it takes more than a few seconds to dissapear & is louder when revved !! So i would say it is not that..
    I would take it to a trustworthy garage, One that is not going to Rip you off for a fault that isn't really a fault & let then diagnose, Either that or a friend of a friend Etc that Knows his Knocks from His rattles.
    Listening down a screwdriver shaft with it pressed to the engine can help pinpoint, Even better with a Stethascope
    But be prepared an engine sounds Terrible through one of these
    Dean
  1. Engine noise on start up
    By Brockettuk in forum Engine & Drivetrain
    Last Post: 24th August 2011, 17:06
  2. Noise on start up
    By andyb28 in forum Engine & Drivetrain
    Last Post: 11th April 2010, 21:26
  3. squeaking noise on start up?
    By darlodouth76 in forum Vectra C / Signum Car Chat
    Last Post: 16th March 2010, 19:29
  4. start up noise on 1.9 CDTI 150
    By gnomes in forum Engine & Drivetrain
    Last Post: 18th February 2008, 10:22
  5. Odd Noise On Start Up
    By sturgi in forum Vectra C / Signum Car Chat
    Last Post: 3rd June 2007, 20:55
vectra noise when first start up then goes quiet
