Results 1 to 10 of 16
Thread: sub and amplifier
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    Default sub and amplifier
    hi all after 2 weeks of installing my sub and amp i was driving along the other day and the amp went into protection mode and now wont work at all ive tried the fuses they are ok and i checked all the wiring which is the same as it was when i put it in. the only thing i noticed is that my left fog light had blown could this be a coincedence or has it something to do with it? hope this makes sense!!!!
    member of the smoke patrol 230bhp+
    disconnect the speaker to see if the amp powers up as it may be the speaker not the amp
    Feb 2007
    Quote Originally Posted by chrisgettings View Post
    hi mate i did that and the only wires connected to the amp were the live and earth and it did the same. it is powering up because a red light comes on next to where it says "protected". could it be the amp is no good?
    Regular Member Signum_CDTI's Avatar
    May 2007
    Somewhere and Nowhere....
    Check the remote power cable too - mine worked loose at the back of the head unit and did the same.
    look at the fuse to the amp as the amp will still try to power up off the remote lead
    or
    you can get a short bit of wire and put it from the battey live to the remote wire on the amp this is a quick way to see if the fuse may be gone
    Regular Member Burton's Avatar
    County Durham
    check ya ground, disconect it, clean it with sandpaper and reconect.... its a common fault.
    Feb 2007
    Quote Originally Posted by Burton View Post
    will do but its not moved or anything everything was the same as when i installed it!! could the amp have gone?
    County Durham
    i know, but i have seen it a few times, exactly the same, nothing moved but suddenly wont work.
    i usually move the ground to somewhere better, and hey presto, works fine!
    Feb 2007
    cheers mate will try that in the morning
    County Durham
    lol probably wont work, i'll look a t**t
  1. amplifier and fan to suboffer
    By Manuel R.B.B in forum Styling
    Last Post: 4th August 2009, 16:02
  2. Aerial Amplifier
    By lizard in forum Electrical & ICE (including SatNav)
    Last Post: 31st July 2009, 10:07
  3. Amplifier Rating
    By siz1 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd December 2008, 10:46
  4. Amplifier on oem DVD90
    By WhiteC in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2008, 19:07
  5. Amplifier Wiring How 2
    By parapaul in forum Vectra C / Signum Car Chat
    Last Post: 18th November 2006, 06:56
