Results 1 to 10 of 15
Thread: P0190 Rail Pressure Range / Performance.
    Jan 2008
    West Wales
    Default P0190 Rail Pressure Range / Performance.
    Mornings,
    Has any ever seen this code "P0190 rail pressure range / performance".
    Had the car on tech 2 the other day as Engine Mgmt light had come on (spanner). Though it ran fine and cleared after start. On a few occasions it had gone in to limp mode the only code was this but restarting resolved. Vx suggested it may be the fuel pressure regulator at fault....
    Questions are :
    Anyone ever seen the above code.
    Anyone ever replaced the fuel pressure regulator.
    How expensive are they?
    Rgs
    Bobby
    which engine matey?..
    Jan 2008
    West Wales
    Default Doh!.
    1.9 Cdti - 150 model.
    What a muppet!
    Rgs
    Bobby
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Quote Originally Posted by bobby_rstevens View Post
    Mornings,
    Isn't there a Fuel rail pressure Sensor on the Jtd lump (Or have i dream't it) & if that was failing it would give Range/Trim errors Etc
    Dean
    Jan 2008
    West Wales
    That sounds just the ticket - where do I locate one of these and anyone know more about what it does?
    Could using a tuning box cause issues? Not that I have but it is possible one could have been used before I bought the car..... just a thought.
    The Vauxhall Technicians said they where unsure and had not seen the code come up before......?
    Your help is apprecaited.
    Rgs
    Bobby
    the pressure sensor is on the end of the common rail.... if it's giving an error, change it..
    Jan 2008
    West Wales
    Thanks Dude....
    You make it sound sooooooooo easy.
    I will take a look under the hood later today and see if I can spot it.
    I don't suppose anyone knows a part no. or a good place to purchase or will it be a stealer only part?
    Apprecaited.
    Rgs
    Bobby
    Jan 2008
    West Wales
    Is the sensor the module bolted to the end of the rail then or the yellow/black plug?
    I hope this helps?
    EVERYWHERE
    It's the one bolted to the end of the rail.I'm not sure if the system needs to be depressurised in order to remove it safely?
    Jan 2008
    West Wales
    MMmmmm as it's a pressure sensor I guess so. I presume they have a pressure release valve like on petrol injected engines.
    Like a tyre valve you release until no diesel comes out. Replace the pressure sensor then how do you reinstate the pressure in the rail? hold the valve in (release valve) until fuel comes out?
    Anyone aware of a part no. or cost?
    Thanks again for your assistance, really apprecaited.
    Rgs
    Bobby
  1. Fault Code P0093 Rail Pressure Range/performance??
    By MarkV6cdti in forum Vectra C / Signum Troubleshooting
    Last Post: 6th November 2012, 16:46
  2. Prefacelift V6 CDTi Rail Pressure Sensor
    By smitd004 in forum Engine & Drivetrain
    Last Post: 6th February 2011, 18:05
  3. Fuel Rail Pressure Sensor - another thread
    By Stevo2 in forum Engine & Drivetrain
    Last Post: 30th June 2010, 20:52
  4. Fuel Rail Pressure sensor
    By RobW in forum Engine & Drivetrain
    Last Post: 3rd December 2009, 16:55
  5. V6 Diesel - fuel rail pressure issue
    By Phil in forum Engine & Drivetrain
    Last Post: 5th August 2009, 22:08
p0190
p0190 opelP0190 zafiraOpel DTC P0190-11p0190 opel vectraP0190-07 opel 1 3 cdtivectra c fault code p0190vectra c p0190 błądvauxhall fault code p0190vauxhall p0190Vauxhall DTC P0190-02p0190 vectra c cdtiP0190 vectra cVauxhall DTC P0190-11vectra fuel railcorsa rail pressure rangeperformanceopel vectra c p0190opel astra z17dth p0190p0190 vauxhallP0190-07 opel cdtip0190 opel vectra cp0190 blad vectra cP0190-05vauxhall insignia common rail sensoropel vectra c 2005 diesel 1.9 common rail
