Page 1 of 6 123 ... LastLast
Results 1 to 10 of 54
Thread: I Give Up.....
    Regular Member Signum_CDTI's Avatar
    May 2007
    Somewhere and Nowhere....
    Default I Give Up.....
    Tried several times, without success to create an MP3 CD for use in the car.
    It is a CD 70 unit which is MP3 compatible (I am right here arent I?!?!?!). I have tried with itunes, and that created MP4 - which are useless.
    I then tried creating a Data Disc using Media Player - only for it to produce WMA files - where the H*ll am I going wrong with this?? Really doing my head in now!
    Any help gratefully accepted!
    Regular Member Simo87's Avatar
    Jan 2008
    Middle Wallop
    Have You Heard Of NERO? I have been using it for years making mp3 disks and ive never had a problem with it, think its probably one of the only software out there that actually lets you burn a disk how you want to burn a disk. just start it, click audio cd, then jukebox mp3, drag and drop the files and click burn, it takes seconds!
    Simo
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    do you have your mp3 files in folders? Just drag and drop the files onto a blank cd.
    May 2007
    Quote Originally Posted by Simo87 View Post
    Simo
    Used to have it - but cant find the CD for it now. Can you get it online as a download?
    May 2007
    Quote Originally Posted by lofty View Post
    They have created themselves as MP4 files from itunes - why has this happened??
    Jan 2008
    Middle Wallop
    Wink
    Think You can get a trial version from their website, if not u ever heard of utorrent?
    [Ex]Admin Duncan's Avatar
    Andrew, in WMP all you have to do is select the tracks you want from your ripped CDs and make a playlist, then burn the CD. It will automatically burn these as MP3. Job done.
    May 2007
    Created a playlist before D, had 700MB of what I thought would be MP3 files converted to Data. Burnt these onto CD, put it in the car and cam up with "INVALID DISC"
    Checked on comp and found that files are WMA files, not MP3's
    May 2007
    Found an option on the WMP under Data CD - says "Writa Playlists to CD as M3U (audio only)" That what I need to do?
    @home
    Engine : 1.9 CDTi
    From WMP select the burn button at the top. Then from your playlist drag the files across to the burn list and select the burn button..
    Never done it this way myself but it should work.
  1. Do you want to give more than 100%?
    By boba in forum Comedy & Humour
    Last Post: 19th June 2012, 20:04
  2. Oh FFS, I give up...
    By Ian-Highlander in forum Vectra C / Signum Car Chat
    Last Post: 15th September 2011, 21:40
  3. give me more bhp please help
    By madmark in forum Diesel Engine related
    Last Post: 10th October 2008, 07:15
  4. Never give up!
    By nutron in forum Vectra C / Signum Car Chat
    Last Post: 4th November 2007, 12:46
