Thread: Noisy A/C
    Regular Member multi's Avatar
    Jan 2008
    east anglia
    Default Noisy A/C
    Finally the sun has started to come out which is a very welcome change, Put the A/C on and there is quite a distinct whining noise coming from it. Is this a common fault or is it something more sinister? Is there an easy cure or will it need to go to Vx?
    Cheers for any help folks
    Oct 2006
    Waterloo, Liverpool
    12 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Could be coming from the fan behind the pollen filter. recently had an issue with my AC whistling, which was caused by previous water ingress from a blocked scuttle and drain. WD40 sorted it out.
    Full Member Big Sig's Avatar
    John, WD40 is not a lubricating oil it is a penetrating spray that will remove grease. Try a few drops of oil to lubricate the fan again.
    Oct 2007
    Gloucester
    Sounds like the problem I have. How easy is it to access the offending fan to give it a dose of lubricant?
    farnborough
    you should give your A/C a blast every month or so just to keep it ticketyboo.
    Oct 2007
    Gloucester
    I do that as a matter of course - especially since Vx replaced my air con compressor for me (how kind!!)
    Hasn't stopped the squeaking fan though!
    Oct 2007
    Scotland
    I have this "whistling" too until the fan settles down. How do I get into it to lube it?
  1. Noisy Fan!
    By suresh.chohan in forum Electrical & ICE (including SatNav)
    Last Post: 9th April 2011, 20:30
  2. Noisy Top End
    By viper8 in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2011, 09:45
  3. Noisy Air con
    By chief29 in forum Vectra C / Signum Car Chat
    Last Post: 11th December 2009, 19:19
  4. noisy car
    By mac12 in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2007, 14:08
  5. noisy air con
    By John35 in forum Vectra C / Signum Car Chat
    Last Post: 13th September 2007, 14:14
