Thread: How Do I Fix My Vectra Dash Lights?
    Lincoln
    Default How Do I Fix My Vectra Dash Lights?
    HOW DO I FIX MY VECTRA DASH LIGHTS?
    I HAVE NO LIGHTS ON MY ISTRUMENT PANEL, HAETER LIGHTS ARE WORKING BUT THAT IS ALL THAT ILLUMINATES WHEN I PUT MY LIGHTS ON. I HAVE a MILLIAGE READ-OUT AS NOTHING ELSE ILLUMINATES. HELP? the speedo not lights as for the rev counter and fuel and temp any ideas my car is a 1996 vectra 1.8 16v looked for fuse but could not find one any where is it the bulbs ??
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    The main fuses are located behind a cover on the left hand end of the facia (you have to open the passengers door), with additional fuses and relays located in a box on the l/h side of the enging compartment, and in the l/h side of the luggage compartment. Looking at the W/D it looks like the instrument cluster uses fuses F17 (15A) and F26 (7.5A) in the passengers box. Hope this is of some help.
    OP's car is a Vectra-B, so the fusebox will below the steering wheel. Waste of time looking in there though as I suspect the backlights have blown. You'll need to remove the speedo housing to replace them. Over on vauxhallownersnetwork.co.uk there is a how2 section. Look in there for the info on removing it.
    Jul 2006
    TENTERDEN KENT
    OP'S teach me to read the thread in more detail.
  1. lights on dash
    By stuk2000 in forum Electrical & ICE (including SatNav)
    Last Post: 21st January 2013, 12:21
  2. spanner lights on the dash of my vectra c facelift 1.9 cdti 120
    By danielle7906 in forum Vectra C / Signum Troubleshooting
    Last Post: 16th June 2012, 18:10
  3. led dash lights and side light running lights
    By fjaimo10 in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2012, 21:21
  4. Dash lights
    By VECTRA HEAD in forum Electrical & ICE (including SatNav)
    Last Post: 29th December 2010, 22:42
  5. dash lights
    By happypostie in forum Electrical & ICE (including SatNav)
    Last Post: 11th June 2009, 09:18
