Results 1 to 10 of 15
Thread: Stupid Sump Plug but Good Ending
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    Default Stupid Sump Plug but Good Ending
    Ok, Ill start with a tip...
    If your sump plug is stupid like mine and is on stupidly tight and breaks 2 Torx keys then you can drain the oil from a sender on the front of the sump.
    Anyways as you can tell i tried to change my oil today, used the engine flush but when it came to taking the oil out, the sump plug wasnt having any of it and decided it didnt like both of my torx keys. Back to halfords for a refund. Anyway had to get the oil out somehow so used the oil sender at the front of the sump. End result nice fresh oil and new filter
    Can i get the hex key sump plug and simply replace it? If so anybody got a part number?
    Aberdeen
    Had the same problme yesterday the slump plug was not budging. Spent two hours under the car with no success, Eventually gave up and went to VX, took them 5 minues using a blowtorch and a very big wrench!
    Regular Member poves's Avatar
    lancashire
    Quote Originally Posted by TheWildHaggis View Post
    LOL , just use a hammer and chisel , the plug protrudes so u can get it started with the chisel , then get a new plug from vx , bout a fiver i think.
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by Mugualigwian View Post
    90502556 for the plug, 90528145 for the o ring.
    Aberdeen
    Duncan to the rescue one again.
    if you like i'll remove the plug... based in leighton buzzard..
    Regular Member Dave1.8's Avatar
    Oct 2007
    Ellesmere Port
    Is that the same for all cars Duncan?
    Not sure, there are some differences depending on the engine. I'd need to check.
    Oct 2007
    Ellesmere Port
    Mines a 1.8 non VVT. Would be usefull to know this for next oil change.
    I'll dig the part number out for you a bit later.
  1. Spark Plug & Sump Plug Torque setting - Z18XE Engine
    By wafoo in forum Engine & Drivetrain
    Last Post: 4th June 2012, 21:15
  2. The life is ending for the spark plug..........
    By Bigtee in forum Vectra C / Signum Car Chat
    Last Post: 26th April 2011, 10:18
  3. Stupid sump plug 19 cdti
    By Mopar Man in forum Diesel Engine related
    Last Post: 11th February 2011, 23:05
  4. sump plug on my 2.2 sxi
    By smilerwas in forum Vectra C / Signum Car Chat
    Last Post: 6th March 2010, 22:53
  5. Sump plug
    By Daywalker in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2009, 19:48
