Thread: Signum Rear Brakes
    Aug 2007
    Wigan
    Default Signum Rear Brakes
    Does anyone know how to press back/screw back the piston on the rear brakes when replacing the pads?
    Ian L
    11 Post(s)
    You need a wind back tool. See the post in the how2 section for all the info.
    http://forum.vectra-c.com/showthread.php?t=15092
    If you just try and push the pistons back into the calipers, you'll knacker them up.
    Regular Member poves's Avatar
    lancashire
    you can get away using mole grips in an "emergency" if your careful ..... I think.they wind in one goes clockwise the other anti clockwise . Hope I remembered rite
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    I changed the rear pads today on my 2.t,same process.
    I tried to use long nosed pliers as i couldnt get hold of the rewind tool..although i could rotate the pistons clockwise i couldnt get them to actually wind in.
    15 minutes with the rite tool and the job was done.
    Good Luck
    yep, use the correct wind back tool or risk ruining the caliper..
  1. Signum rear brakes
    By R13hard in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2013, 13:07
  2. Signum 2.2 Brakes
    By DarrenLee in forum Handling & Braking
    Last Post: 16th June 2012, 22:25
  3. Signum Brakes
    By raddish in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2010, 12:52
  4. Signum Suspension and Brakes...
    By MatS'ignum in forum Handling & Braking
    Last Post: 4th October 2008, 21:22
  5. scraping noise from rear. rear brakes? upgrade?
    By Whippy in forum Suspension, Wheels & Brakes
    Last Post: 5th March 2008, 01:26
