Thread: Replace NCDC 2013 sat nav with CD70
    Bedfordshire
    Default Replace NCDC 2013 sat nav with CD70
    Hi all
    I have a 52 Plate Vectra with a NCDC 2013 sat nav system with a mono screen.
    Is it possible to change the head unit to a CD70 system, if it is possible what would have to be done, i.e. swap the head and put in the code for the CD70 or do you need to go to the main dealer and have the unit paired to the car? I'm not bothered about changing the mono screen.
    I have searched for an answer to this, but I am still not 100% clear if it can be done.
    Thanks for any help in advance.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    your car is half canbus (ISO fixings for Stereo) and the CD70 I think requires full canbus so the answer is no. You would be better off getting a new double din stereo with satnav all built in .
    You would not be able to use the mono screen with the CD70, u would need the coloured screen anyways
    Quote Originally Posted by merikiito View Post
    Some of the earlier cars had mono screens fitted for the CD70.
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    It is not impossible (Badevil from German Motor-Talk-forum has done it), but it is complicated
    You need a CD70, a CID, new frame and air vents for the CID, new ECC (if you have one fitted), a RGB-cable + the connectos of the existing cables needs changing (aerial ta Fakra, ISO...) + a Tech2 session
    the steering wheel controls must also be replaced
    Btw, a CD70 can work with a monochrome GID, however I don't know if the one of a NCDC will do.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    If you can get a CD70 with half canbus then it might work, if they did one. Mind you the screenstill might not work.
    Bedfordshire
    Thanks for the info all, what's the easiest to tell if you have a full Can-bus system?
    Regular Member pricey's Avatar
    Dewsbury, West Yorkshire
    Your's is a 52 so it'll be half canbus.
    Full canbus was introduced in the second half of 2004 but the easy way to tell is; half canbus - 3 buttons each side on steering wheel controls,
    full canbus - roller wheel controls.
    Bedfordshire
    Thanks for all your help, I'll give up on the idea of replacing the NCDC 2013 sat nav.
    Poland
    In my opinion it would be the best to change the screen from GID, to a CID for NCDC navigations. You can buy such display much cheaper than a display for a cd 70. I don't know how much in UK, but in Poland under 100 quid.
    And with this CID you don't have to change the ventilation vents.
    Regular Member phe's Avatar
    Feb 2006
    Guadalajara (Spain)
    Vehicle : Vectra OPC
    Engine : Z28NEH
    Mileage : 120.000km
    Hello from Spain
    If you want to change an NCDC by CD70, you need to change:
    - Conversion conector Iso -> quadlock (and fakra)
    - NCDC -> CD70 (or others CDx0)
    - Display model "< 2004" -> Display GID/CID >2005
    - if have ECC -> change for the ECC module >2005
    Optional:
    - Controls model 2005 or Steering wheel with controls + airbag
    Program all whit tech2
    I have changed one CCRT-2008 + CID for one CD50Phone + CID 16:9, include the ECC module
    Another user have changed one CCR-2005 for one CD70Navi, In this case it is necessary to add cables to canbus
  1. Ncdc 2013 /sub
    By jodiexii in forum Electrical & ICE (including SatNav)
    Last Post: 24th October 2012, 00:29
  2. Ncdc 2013
    By khile in forum Electrical & ICE (including SatNav)
    Last Post: 24th March 2010, 00:05
  3. CD70 / NCDC 2013 Nav discs
    By gtr1000 in forum Electrical & ICE (including SatNav)
    Last Post: 28th December 2007, 20:44
  4. Ncdc 2013 Help
    By mickeystitch in forum Electrical & ICE (including SatNav)
    Last Post: 19th April 2007, 18:12
change ncdc 2015 with cd70
https:www.vectra-c.comforumshowthread.php44828-Replace-NCDC-2013-sat-nav-with-CD70
cid cd70 on ncdc 2013
ncdc 2013 sat nav
does navi 70 cd work in ncdc
replace ncdc2013 cd70 navi
ccrt 2006 change cd70 navi
ncdc2013 new navi
