Results 1 to 10 of 25
Thread: Help needed from a sxi1.8 52 plate owner-URGENT
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Default Help needed from a sxi1.8 52 plate owner-URGENT
    Hi,
    I need help from a fellow 1.8 SXi 52 plate owner.
    This could be going beyond the call of duty for a fellow member of this forum!
    Problem.
    I am replacing the airbag module due to a failure.
    I went to Vauxhall and got the part number for my car (my local dealership orginal sold the car). I aquired the part fitted it and gave the car to my local VX dealer to tech 2 it in. Now my dealer is saying it is the wrong part!! and they cannot get it to tech 2. It seems that the Airbag module is the one for the two phase airbag system where as mine is single phase.
    Now VX says on TIS there is only one part number so the dealership has contacted VX Techincal who say they need the IDent code on the orginal module (2 capital letters) to be able to get me the correct module. Now here is the problem. The orginal airbag module has been thrown away so I cannot give them the IDent code (also I found out you can get the airbag module reprogrammed via Ebay for £60 so not happy ).
    So is there an owner of a 1.8sxi 52 plate who is willing to take out the centre console and get me the IDent number? Long shot I know but VX are no help. It may be possible to view it by removing the gearstick cover and or the drinks holder. Any help please?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    bump
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Still need help, need the part number as well now as VX have no idea what was fitted in my car!
    farnborough
    Try calling your local scrappy and ask if they have one there... then go have a look
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    what is the part nr. that you ordert? (because then i can se i EPC where it fits)
    and if i can get the last 8 digitets of the serial nr. of the car i can se what to find.. (via EPC). (you can send it as PM)
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by kenp View Post
    Thanks for trying to help with EPC. It was Vauxhall that gave me the part number based on my Vin (my local dealer sold the car orginally). What they did not tell me was the IDent code, usually a two digit capital letter code on the module itself. Have been in touch with VX tech who CANNOT tell me the ident code. I have to get the code off the old module (which was thrown away by the fitter as he was fitting a new one so did not need it anymore!). So now i have to try and get the code off a similiar aged/model car. The problem is that my car is single phase airbag system and not the later twin phase airbag system.
    Part number that I was given was 13142540 supplied with ident code GP which has turned out to be twin phase airbags only.
    My local dealer says that should be the one for the car but they now say it is not the case and they do not have a clue.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I need to confirm the part number and IDent number
    farnborough
    did you read what I suggested?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by freshprince View Post
    Yes I have but the part is rarer than rocking horse po*
    Have been trying to get one for over 8 months before buying one from VX
    farnborough
    well, I'll have a check and see if anyone can find an answer my end and if so i'll let you know
  1. urgent help needed?
    By webber446 in forum Engine & Drivetrain
    Last Post: 11th January 2012, 14:30
  2. urgent help needed >>>>>>
    By justin79 in forum Electrical & ICE (including SatNav)
    Last Post: 11th August 2011, 20:02
  3. Urgent help needed
    By Topcat4500 in forum Engine & Drivetrain
    Last Post: 11th February 2011, 19:39
  4. Urgent help needed please
    By daddy07 in forum Engine & Drivetrain
    Last Post: 3rd October 2010, 13:31
  5. urgent help needed
    By callum in forum Vectra C / Signum Car Chat
    Last Post: 22nd April 2010, 11:09
